:::::: What lug nuts do you run? ARP extended studs problem
Old Sep 24, 2012 | 09:57 AM
import-tooner's Avatar
Default :::::: What lug nuts do you run? ARP extended studs problem
So, I just installed ARP extended studs on my 98 civic hatch. I have extended lug nuts too. I think they were buddy club but they're probably replicas or something. Anyway, when I went to put on my studs they went about 80% of the way down and wouldn't go any further. Almost like the threads were cut incorrectly. So my question is this. What lug nuts do you run with your ARP studs??
Old Sep 24, 2012 | 03:14 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Default Re: :::::: What lug nuts do you run? ARP extended studs problem
Are you sure your lug nuts arent bottoming out because your studs are too long?
Old Sep 24, 2012 | 07:07 PM
macDelli's Avatar
x2.. unless they're open ended?!
Old Sep 24, 2012 | 07:52 PM
They're open.
Old Sep 28, 2012 | 09:29 AM
sohc95vtec-t's Avatar
Were you forcing the lug nut on before it bottomed out at 80%? They should thread on easily, almost sounds like either the lugs, or the studs are 12x1.25 rather than the correct 12x1.5 thread pitch
Old Sep 28, 2012 | 05:02 PM
DaltonH's Avatar
^x2! make sure they are the same thread. if you have used those lug nuts before on the original studs, then the arp's are probably the wrong size
Old Sep 29, 2012 | 03:23 PM
gsrturbo-ek's Avatar
when i did my arp extended studs my blackworks extended lugs had a hard time goin on.. i put them on and took off a couple times and now they go on smooth with out a problem
few of my friends had same problem and fixed it that way
HCivExoo
Jan 18, 2009 06:36 AM
jerbear!
May 3, 2006 05:15 AM
bigBOI_92DA9
Aug 14, 2005 08:03 PM
