ej1 rear disc swap question
Old Sep 24, 2012 | 09:19 AM
Wilka's Avatar
Default ej1 rear disc swap question
Ok, i have arear disc swap in my 94 ex, trying to figure out which rear disc they are so i can order all new pads and rotors, are they the same thing? How can i tell just by looking at the caliper or rotor?
Old Sep 24, 2012 | 02:17 PM
EJ8_Man's Avatar
Default Re: ej1 rear disc swap question
Assuming your calipers and rear trailing arms are OEM from the same vehicle they are all the same for rear disk, Civic Si or Integra LS you pick. What did you get your rear trailing arms off of? Use the replacement disks for that
Old Sep 27, 2012 | 04:53 AM
Wilka's Avatar
How can I tell, I bought the car with it already done.
Old Sep 27, 2012 | 07:28 PM
teamXteg's Avatar
-Rear trailing arm with hub assembly for disk brakes (92-95 EX/SI, 96-00 DelSol Vtec, 96-00 EX, 99-00 Si, Integra 94-00)
-All of the Integra rear disks are the same for the 3rd gen, so any of the 3rd gen (DC) brakes will work.
-Also, the 99-00 Si rear brakes will work. I believe that these are the same as the rear Integra disks as well.
i believe the only eg civic to come factory with rear disk is the EX with anti-lock. under the hood on the passenger side by the end of the intake filter there will b a box with a lot of lil metal lines bolting into it. Thats the easiest way to see if its a factory anti lock system i think. if the box isnt there then i would belive its the popular dc rear disk swap
Old Sep 27, 2012 | 08:32 PM
k20jonny's Avatar
isnt there a cast number on the brake caliper?
Old Sep 30, 2012 | 10:59 AM
Wilka's Avatar
Thanks guys, I do have the abs box, don't think it works too well though. I must be stock then.
swifty4u
18
Sep 15, 2005 02:42 PM
RA61825
Apr 2, 2005 01:11 PM
eK9aT10pSi
71
Feb 7, 2005 12:25 AM
Ricey McRicerton
18
Sep 29, 2004 09:40 AM
endlesswinterco
Oct 27, 2003 02:59 PM
