Looking for someone to finish my shiz d16y8 rebuild.
I blew a headgasket on a d16y8 in a 00 coupe. Ive had it parked for a while and I started ripping everything off it to replace the gasket, clean it up, and refresh a lot of the engine. I work too much, had all my tools stolen and had to replace with shitty husky's and am getting married and just dont have the time to finish it.
PM me a quote on finishing my job. I will have all parts purchased and ready to go. The head will be off the car and you will be required to install it back while replacing the following.
all new belts,
all new fluids,
new gaskets,
headgasket
plugs,
wires,
cap,
rotor,
set timing,
timing belt,
water pump,
fuel filter,
ac,
radiator hoses/new radiator
etc.
Depending on my laziness level you may also need to clean off any build up around piston walls.
I live in the High Desert and it should be a one day job, if you do not think you can finish it in one day then let me know in advance. I've done a similar job in just a few hours but I'm so over doing it again when I'm working this much.
If you can do a clutch let me know the price on that as well.
all new belts,
all new fluids,
new gaskets,
headgasket
plugs,
wires,
cap,
rotor,
set timing,
timing belt,
water pump,
fuel filter,
ac,
etc.
utrules
Jan 31, 2011 01:37 PM
