Auto to Manual ECU Question
2000 Accord... ECU from same year car has one less receptacle for plug, do I need to do anything with extra plug, repin?.. thanks
Confused about electrical connections including VSS in general... do i need to repin for vss.. I am referencing the old accord auto to manual thread...
cut this from thread.. is this the best way to do it?...
VSS Wiring
This is a simple fix to make the vss/vtec work. if you want to edit this to make it work better, have at it.
lets use this pin diagram:
http://www.driveaccord.net/forums/at…5&d=1111724327
depin the #10 on connector D and install onto 23 on connector C. depinning is a ***** but it must be done for your sake. as far as the vss, i cant confirm wire colors, but when you are looking at the plug, with the clip part on top, the wiring is as follows… ground / power / signal.
now the speedo has to be tee’d off. the auto got an input from the vss to the ecu the sent another signal to the speedo. somewhere along your vss signal line, splice the wire with the blu/wht wire running to the back of your speedo. the other end, not connected to the cluster, is on the pass side behind the fuses.
VSS Wiring
s73
10
Jan 7, 2005 12:10 PM
