Can someone tell me where these plugs go?
Old Oct 17, 2002 | 01:05 AM
lost password's Avatar
Default Can someone tell me where these plugs go?
I have an OBD1 JDM gsr motor with an OBD2 gsr harness. Its going back into an OBD1 95 gsr teg. I swapped the injector,dist,alt plugs with the ones on the jdm harness. I don't know where these plugs go. The harness was sold to me as OBD1 which it is not. But now I'm wondering if its even a gsr harness!! Can someone tell me:
1. Is this a GSR harness?
2. Where these plugs go?
Old Oct 17, 2002 | 02:33 AM
kenji's Avatar
25 Year Member
Default Re: Can someone tell me where these plugs go? (lost password)
The black plug you are pointing to in the first picture is the Evap purge solenoid plug. You will need to get a round 2 wire plug (very common) from another engine harness and splice it in.
The plug in the second picture is for the CKF (crank fluctuation sensor). OBD1 cars do not use a CKF. Just move it out of the way of moving parts and zip tie it up.
-kenji
Old Oct 17, 2002 | 01:03 PM
Default Re: Can someone tell me where these plugs go? (kenji)
Thanks alot Kenji
The only other thing is where the two harnesses plug together at the pass side shocktower:
1.Is it just plug and play or do I need to change pinouts (everythings obd1 except engine harness)?
2.One plug wont connect to the harness. Car side has 2 wires, engine side 3 wires.
Old Oct 17, 2002 | 05:47 PM
TodaSi's Avatar
Oh, oh can I help? Kenji can I help him with the wiring?
Um, let me see.........
Forget it, I can't wire car speakers for crying out loud!
Sorry
Free bump
vtecftw
Aug 28, 2007 04:27 PM
C1CRX
Aug 8, 2006 08:04 PM
guymosiris
Jun 26, 2006 12:20 PM
R_type
May 30, 2006 08:42 PM
1dopesi
Oct 6, 2005 11:37 AM
