Are 16" JDM ITR 98 spec wheels suppose to sit flush?
Old Sep 21, 2012 | 11:11 PM
mr_munro's Avatar
Default Are 16" JDM ITR 98 spec wheels suppose to sit flush?
Its too hard to get a picture, but i purchased some JDM ITR 16" wheels (5x114.3) for my ITR, and there is a about a 5mm gap when they sit against the hub..
Does anyone know if they are suppose to sit flush against the hub?
Thanks
Old Sep 21, 2012 | 11:28 PM
01-0720's Avatar
Default Re: Are 16" JDM ITR 98 spec wheels suppose to sit flush?
pictures would be best, but from your description something sounds wrong
Old Sep 22, 2012 | 02:50 AM
mr_munro's Avatar
Ill try and get one in a couple of days, once the wheels are back on
Old Sep 23, 2012 | 07:24 AM
00-1065's Avatar
All wheels should sit flush against the hub.
Old Sep 23, 2012 | 10:08 AM
luvmihatch's Avatar
I had the same issue with a set many many years ago. Take a ziz wheels and smooth out the ring on the hub where the axle nut goes in and it should fit flush.
hope this helps.
Old Sep 23, 2012 | 10:44 AM
racebum's Avatar
x2
sand the rust off your hub and make sure they fit. you could use a caliper to measure your hub and the insert in the wheel. you will wobble like crazy and likely have a wheel fly off if you drive without them mated
Old Sep 23, 2012 | 07:52 PM
mr_munro's Avatar
Well thats weird, my other wheels i had on there sit flush, so if i sand the hubs, they wont sit properly if i ever had to switch back to my old rims.
This gap is consistant on all sides of the car..
Old Sep 23, 2012 | 07:53 PM
mr_munro's Avatar
hope this helps.
What do you mean take a ziz wheels?
Old Sep 23, 2012 | 07:56 PM
mr_munro's Avatar
Here is a pic of the hub. If i was to take some off the front, the rims would not clear the caliper..
Old Sep 23, 2012 | 08:01 PM
mr_munro's Avatar
Is there another alternative, can i buy hub centric rings?
http://www.ebay.com.au/itm/CUSTOM-CA...#ht_506wt_1163
Old Sep 23, 2012 | 08:21 PM
coolhandluke's Avatar
Can you take a clearer image of the gap from a top level view?
Do all the JDM ITR wheels have this gap on all four corners of the car?
Old Sep 23, 2012 | 08:32 PM
mr_munro's Avatar
Yes the gap is consistent around all corners. I got under the car, turned the wheel around and the gap is consistant as the hub rotates. I cant fit the camera through the spokes to get a top view.
Old Sep 23, 2012 | 10:38 PM
mr_munro's Avatar
Old Sep 24, 2012 | 12:24 AM
mr_munro's Avatar
Ok guys it seems they sit fine, took it for a long drive. No issues.
What are peoples thoughts running 50 profile tyre at the back and 45 at the front?
Old Sep 25, 2012 | 07:08 PM
X2BOARD's Avatar
Why do you want to have different profiles ?
If you can get 45 series, the best tire I have run on the same rim was a 215/45, otherwise, stick with a 205/50 on all corners.
Old Sep 25, 2012 | 07:27 PM
Clerique's Avatar
215/45/16
And yes, that gap is normal; its just a little taper on the rim
Old Sep 26, 2012 | 07:26 PM
mr_munro's Avatar
Because it is too high, and the front scrubs with 50 profile. I have 2 45 profile tyres in good nick i can stick at the front and just leave the 50s on the back.
Old Sep 26, 2012 | 10:04 PM
With 16'' tire selections being slim, most tire companies will make a 205/45 or a 215/45. I wouldn't recommend a mismatched setup but if you need to get by, do what you need to do. You may have a humming from the different tire diameters though.
giotein
Jun 18, 2012 02:26 PM
91bluehatch
Jun 15, 2010 05:42 PM
len
Jan 23, 2003 09:30 PM
Ferrell
Nov 25, 2002 03:37 PM
