D and B series parts. OBO. No reasonable offer refused :)
D series (all from my EK):
MT Starter $40
Shift linkage with shifter $40
clutch and flywheel $40 (good life left)
Alternator $40
T bracket $10
Brand new driver side axle from Autozone $40
OBD2B P2E ecu $10
AC Compressor Bracket $20
Lower Tranny Mount bracket $10
Clutch release fork $10
Stock intake tube and air filter box resonator too! $40
B series:
B16 Intake Manifold $80
Fuel Rail $40
Injectors(OBD2) $40
B16 Hydro Tranny Case $60 (Clutch housing is a little beat up on the mounting side looks like pry marks from removing the trans. Gear housing main plug housing looks like it was previously jb welded/sealed. Does have all pieces, reverse fork, revers idler gear, gear selector, ***** and springs)
Cable Trans Countershaft set up $? (complete with gears and synchros)
Hydro LS differential $40
LS main shaft $? (B16 gears bad 5th)
LS Crankshaft $50 (Main Journals machined .020" smaller)
B18 lower timing covers (2) $15 OBD1
B18 upper timing cover $10
B18 Tranny mount, good condition $10
B18 Oil Pan $20 (definitely seen better days, but the flange is straight and seals)
Odds and Ends:
EK Coupe tail lights $20
96-98 civic coupe cup holder $10 (broken door assy, just doesnt latch)
EK4 gauge Cluster $100
Im sure there is more, just cant think off the top of my head. Let me know if there is something you need that I havent listed and Ill let you know if I have it.
No reasonable offer will be refused. More pics will be posted.
760-694-7427 Mike
MT Starter $40
Alternator $40
T bracket $10
OBD2B P2E ecu $10
B series:
Fuel Rail $40
Injectors(OBD2) $40
Odds and Ends:
760-694-7427 Mike
MurkyRiversEK
Nov 28, 2012 12:36 PM
EGR95
Northern California (Sales)
May 24, 2009 01:03 AM
EGR95
May 6, 2009 11:13 AM
