Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Engine out need to get pwr windows up
Old Sep 21, 2012 | 04:06 PM
dem0nk1d's Avatar
Default Engine out need to get pwr windows up
So i've removed the engine and still have the harness in the car. I've got the battery plugged in and the harness ground hooked up to the body. The cluster shows check engine flashing, but nothing else works. Anyone have any tricks to getting the windows to work?
Old Sep 21, 2012 | 04:49 PM
lazlong's Avatar
Default Re: Engine out need to get pwr windows up
Only trick I know is to take the door panel off, unplug the window motor connector and apply battery positive to 1 terminal and battery negative to the other. If the window is going the wrong way then just reverse the wires. I usually use my cordless drill battery if it's not under the hood.
Old Sep 21, 2012 | 08:16 PM
dem0nk1d's Avatar
that's one way of doing it, but i have all four windows to roll up
Old Sep 22, 2012 | 02:29 PM
goodmaninblue's Avatar
10 Year Member
It depends what year model your vehicle is. On many early year Hondas, we do have the ability to control all four windows from one single junction.
Old Sep 23, 2012 | 09:06 AM
dem0nk1d's Avatar
2004 lx what is this junction?
Old Sep 23, 2012 | 01:01 PM
lazlong's Avatar
It wouldn't be one junction. It would be one connector, like the master switch connector in the driver's door.
BTW: It only takes 2-5 minutes to take a door panel off.
Boss727
Mar 15, 2014 08:04 AM
JDMEMone
Jun 28, 2012 08:37 PM
sleEKcpe
Jul 29, 2010 04:43 PM
iateshaggy
Aug 17, 2007 06:58 PM
hitekper4mance
Dec 4, 2004 11:51 AM
