car stumbles anywhere past half throttle?
Old Sep 21, 2012 | 01:21 PM
wasp9166's Avatar
Default car stumbles anywhere past half throttle?
so i've had this weird issue for a month or so
car runs fine, even at 70 with low to mid throttle no issues
but when i floor it, it stumbles and doesn't have the pull it should have
so, i replaced the fuel filter, cap , rotor, plugs, wires, timing belt, adjusted valves, ignition timing is spot on
all of this actually made it worse
soooooo, my guess is the more complete burn due to tune up is making it want fuel even more?
can a fuel pump work fine with little demand but not work the way it should upon high demand?
burned valves? clogged cat? egr? o2 sensor?
i have no cel, but i'm assuming it works properly
i dunno, i'm stumped but it's a pia and was hoping someone else has been down this road
main relay is also only a couple years old
91 civic dx
212k
Old Sep 21, 2012 | 01:40 PM
Former User's Avatar
Default Re: car stumbles anywhere past half throttle?
Is the LED on the ECU blinking any codes?
Old Sep 21, 2012 | 01:52 PM
wasp9166's Avatar
it is under the passenger foot carpet? and i need key in 2 position?
i also dumped in some chevron techron thinking maybe it is dirty injectors, nothing
Old Sep 21, 2012 | 02:24 PM
wasp9166's Avatar
well, all i see under passenger dash is the air box and fan
Old Sep 21, 2012 | 02:26 PM
Old Sep 21, 2012 | 02:30 PM
wasp9166's Avatar
yep, found it
it blinks 15 times, then 16 times and repeats
Old Sep 21, 2012 | 02:37 PM
Reset the ECU and then drive the car to see whether one, both, or none of the codes repeats.
Old Sep 21, 2012 | 02:38 PM
wasp9166's Avatar
i'll disconnect pos on batt and leave it overnight, was thinking of doing this anyhow, i'll report tomm, ty
Old Sep 21, 2012 | 02:49 PM
Just pull the Hazards fuse for 10 minutes.
Old Sep 21, 2012 | 02:53 PM
4drEF's Avatar
Keyboard Humorist
Sounds very distributor failure-ish.
Old Sep 21, 2012 | 06:41 PM
wasp9166's Avatar
great
Old Sep 22, 2012 | 05:35 AM
wasp9166's Avatar
well ,just took it out
same problem, but i have no flashing led
replace dist?
Old Sep 22, 2012 | 05:52 AM
replace dist?
I'd drive it a bit more to see whether a code is thrown.
Old Sep 22, 2012 | 06:03 AM
wasp9166's Avatar
ok
i think i'm gonna replace dizzy anyhow, the cardone is only $130
and being the coil and igniter comes with it, i could eliminate a few possibilities
it does have 212k on it
is there a seal behind it like the cam seal on other side? all i see is an o ring on majestic dist blow up
there is alot of oil leakage from behind the diz
well, enough to coat the tranny underneath
Old Sep 22, 2012 | 06:05 AM
There's an O-ring and an internal seal. Is there oil inside the distributor?
wasp9166's Avatar
not that i noticed when i changed cap, but i didn't shine a light in the crevices either
so there is no other seal other than the o ring that comes on the diz?
Old Sep 22, 2012 | 06:06 AM
Remove the inner cover and look inside the distributor for oil.
Old Sep 22, 2012 | 06:09 AM
TeamRedline89Hatch's Avatar
ok
There is an o-ring on the shaft. Sounds like your ignitor might be failing.
Old Sep 22, 2012 | 06:27 AM
wasp9166's Avatar
no oil in diz, was a bunch on the sensor under it that's in the head
Old Sep 22, 2012 | 07:24 AM
That's an O-ring issue.
Old Sep 22, 2012 | 09:47 AM
wasp9166's Avatar
yep, so may as well kill that problem in the process
how do i know if it's a td-01U or td-18U?
the one i have now says tec on the top of it, the coil i beilieve
Old Sep 22, 2012 | 01:05 PM
wasp9166's Avatar
well majestic only says td-01U for the 3dr dx, so i'm going with that
what is the td-18U? in the crx , si or something?
Old Sep 23, 2012 | 06:15 AM
wasp9166's Avatar
bueller?
anyhow, this dist should only fit in one way so there is no reason to have motor at tdc , correct?
also, in the event this doesn't work i was looking at the fi system, there is a primary and auxiliary injector
is the purpose of the aux injector to provide more fuel when the demand increases?
Old Sep 24, 2012 | 02:00 PM
wasp9166's Avatar
well, got on it on way home from work
and it's no longer doing it....lol
it did it sat morning after reconnect
does it take the ecu a day to work out the kinks or something?
just as well, oil seal was leaking and i need this car to last 3 yrs, so at least i'll have a new ignitor etc
Old Sep 26, 2012 | 01:38 PM
wasp9166's Avatar
bueller?
or should i create a new thread?
Tampacb7813
Feb 4, 2020 06:43 PM
netfreak
Aug 29, 2018 04:57 PM
tacorunner87
14
Jan 3, 2009 09:05 PM
boostedEBP
Jan 23, 2008 02:20 PM
letholone
May 8, 2005 02:50 PM
