2000 ITR Tyre reccomendations
Old Sep 21, 2012 | 03:21 AM
dufunk's Avatar
Default 2000 ITR Tyre reccomendations
I have original honda 15"s on the car what size of tyre would you reccomend i.e. 195/55 or 205/50
Old Sep 21, 2012 | 05:06 AM
mayfly's Avatar
Default Re: 2000 ITR Tyre reccomendations
i would go with a 205/50/r15 nitto neogens for summer tires, great grippy tires. dont run the 205's if your sitting to low, you might get some rubbing on the wheel well
Old Sep 21, 2012 | 05:54 AM
dufunk's Avatar
Yeah she is sitting quite low, any higher than 50 profile maybe look stupid on them.
Old Sep 21, 2012 | 05:57 AM
01-0720's Avatar
stock itr wheels are only 6'' wide
205 is to wide, the car will feel sloppy, stick with a 195/50 car will feel better, and there is a far bigger tire selection in that size
Old Sep 21, 2012 | 06:05 AM
dufunk's Avatar
Thats great thanks, I can get 195/45 or 50 R15 nankangs for 35 pounds sterling online which is very good.
Old Sep 21, 2012 | 05:31 PM
00-1065's Avatar
195/50 is too small. 205/50 is the best size.
Old Sep 21, 2012 | 08:39 PM
j13's Avatar
j13
195/55/15
Old Sep 21, 2012 | 10:30 PM
coolhandluke's Avatar
Originally Posted by dufunk
I have original honda 15"s on the car what size of tyre would you recommend i.e. 195/55 or 205/50
What is your application? The best tire for your needs may or may not be offered in 195/50, 195/55, or 205/50/15. What tires are you looking at purchasing?
Also, make sure you familiarize yourself with the tire size calculator:
http://www.carbibles.com/tyre_bible_pg4.html
Most non-JDM market ITR's came with 195/55/15. Use the link above to estimate if your selected size will make a difference on your speedo.
Old Oct 9, 2012 | 12:22 PM
Howat's Avatar
Originally Posted by j13
195/55/15
thumbs up! factory specifications!!
Old Oct 9, 2012 | 12:30 PM
Black R's Avatar
25 Year Member
195/50/15 will give you better acceleration and lower the car a tad...
Old Oct 10, 2012 | 08:59 AM
Todd00's Avatar
I said I don't want a title!
195/55/15 is stock. A 205/50/15 will work just as well, but will be a bit 'sloppier' on a 6" OEM wheel. Sidewall height between the two are almost identical. Remember, sidewall height is a calculation and not a fixed amount.
Dunlop makes the Direzza Star Spec in a 195/55/15 and it is a fantastic tire for the OEM wheel (assuming you can run a summer-only tire all year or have snow tires for the winter).
Old Oct 10, 2012 | 10:33 AM
atc5's Avatar
Originally Posted by Todd00
Dunlop makes the Direzza Star Spec in a 195/55/15 and it is a fantastic tire for the OEM wheel .
Just mounted these on Sunday...looking forward to get some seat time with them.
Old Oct 10, 2012 | 07:46 PM
bryantjoe's Avatar
I second this wholeheartedly! I've had these tires on My EvoX when I had it and I've got them on the R too. Decent in the rain too. I would definitely not recommend them for winter though.
Old Oct 10, 2012 | 08:02 PM
I wouldn't recommend a tire from any summer category for inclement weather.
Old Oct 11, 2012 | 08:03 AM
lzylst's Avatar
Hmmm, 6 inches wide. I always thought the were 6.5" wide.
Old Oct 11, 2012 | 11:47 PM
HYREV2NR's Avatar
My preference is 205/50.
Old Oct 12, 2012 | 06:39 AM
SF_EF8's Avatar
Ive had 195/55 and a 205/50 on mine.
There was not much difference except the better grip coming from the better brand of tire the 205 was.
Old Oct 12, 2012 | 07:40 PM
Howat's Avatar
Will be mounting my newly purchased 195/55/15 Goodyear Eagle GT tomorrow. Wish me luck!
Anyone interested in the purchase of nearly new Yokohama S Drives?
Old Oct 14, 2012 | 02:06 PM
Alfabarn's Avatar
Curious about that too...are stock ITR 15s 6" Or 6.5" ?
Old Oct 14, 2012 | 04:07 PM
Todd00's Avatar
OEM ITR wheels are 15x6". Those who say otherwise are wrong.
eg.reddragon
May 17, 2013 12:22 PM
B3AS
Oct 25, 2006 10:58 AM
SpeedingHatch
Mar 10, 2006 06:48 AM
kupras
Aug 25, 2005 06:38 PM
Hexxboy
Apr 30, 2002 02:33 PM
