1997 Civic LX Improvements
I'm probably due replacing my old shocks/struts but I'm on a pretty tight budget. I was wondering what would be the best for the money? I was also considering a sway bar. Would that be a good option?
My car is a commuter and I don't want to change the ride height or stiffen the suspension to uncomfortable levels. Since my car is a commuter I need to keep high mileage tires on it but I was considering some Hankooks probably the 80,000 or 100,000 mile tires from Discount Tire.
Last edited by jrunager; Sep 20, 2012 at 04:52 PM. Reason: Intended to add suspension into my Title...oh well that won't edit
Do a full bushing set. Hardrace, energy suspention, or suja1 all make great bushing kits and they are under 380 for a full set u will feel a huge difference
Not exactly the advice I was expecting but it sounds like good advice. I looked at the energysuspension on Summit and I'm a bit confused as to what kit I will need.
Throw a set of OE replacement shocks and call that a day.
a rear sway bar would definetly be an improvment. 99-00 SI, or 94-01 Integra (non R) will work..
A far as the bushing kit. Hard and PIC are great. IIRC, the PIC kit is actually cheaper then the hardrace and is a bit stiffer.
Take a look at the bushing kits and come back with any questions.
I will warn you, install is a pain in the ***!
This kit seems kind of cheap...Is it not as complete at those others or just not as good?
http://www.summitracing.com/parts/EN...103R/?rtype=10
Would this one by chance?
http://www.summitracing.com/parts/ENS-16-3114G/
Forgive the noob question but what would make this a complete kit?
What would make it a full would be it having all of the bushings in it, such as the Hardrace or PIC kit.
Ah I think I found the full kit. Is this one it?
http://www.summitracing.com/parts/ENS-16-18110G/ oops nevermind this one doesn't look like a full kit either.
If I find a full bushings kit within my budget I'm thinking I'll go with a rear Integra or SI sway bar, and shocks (I'm thinking about Bilstein shocks).
If I did these three changes how much improvement would I be able to expect? Or would I be hurting the handling of my car by leaving something important out?
No ES is a full kit for this car.
Take a look at this. This is a full kit.
http://picperformance.com/store/scri...?idProduct=233
All 3 will be an improvment.
these cars aren't getting any newer and the stock bushing wont last forever, if they already aren't in need of replacement.
Putting a rear sway bar on this car will diferenty be a noticable upgrade.
Bilstiens are good.
What I also reccomend, taking a look at the suspension as in, ball joints, tie rods, etc. See what needs to be replaced and do it all at once.
Don't forget to get it aligned!!
Bilstiens are good.
If you're on a budget and looking for shocks I'd recommend APX shocks on Ebay. I know plenty of people will bash alleged ''no name" parts, but after doing some research before purchasing them, I found that they make the OEM shocks/struts for Volvo and another company that I can't recall right now. I had them on my EJ8 because I needed new shocks ASAP and at the time they were all I could afford and they were exceptionally comfortable; Even with a mild drop on springs, they functioned well. I believe they were somewhere in the range of $120 for all 4.
I think that leaves me with plans to do a rear sway bar, bushings and possibly shock/struts...nothing fancy I guess.
Has any magazines or anyone track tested a gen 6 Civic with mild suspension modifications like these and documented the numbers compared to the stock number... I think the factory has my car pulling something like a .77g which isn't exactly burning up the track but hey it is a base model econo car.
How mild are we talking here? I promis everything you can think of doing to this car has been done, or someone has taught about doing it.
Don't forget TIRES! Quality tires are key
I would like to find some 15" Honda, Acura or other factory looking budget wheel to replace steel wheel with busted covers I already have (one is slighty bent). I have to stay with high mileage tires because I drive a lot of miles in one day so I'll probably goe with some of the Hankook high mileage tires (60,000 to 100,000 mile tires).
Digitalis
May 21, 2015 09:15 PM
mingchi69
Aug 18, 2003 07:36 AM
