Prelude Build Question
Old Sep 20, 2012 | 03:06 PM
Yannx13's Avatar
Default Prelude Build Question
This winter i'm about to build my H22 (Head & around). Fast said, i'm gonna upgrade to Skunk2: TB 74mm, Pro Series IM, 2''½ Cat-Back, Vibrant Headers, and own a ported head(Intake & Exhaust) with oversized S2 Valves and valvetrains. I was thinking going with Pro 2 cams with OEM pistons which I figured out might be a bad idea.
Any ideas what pistons I could get? Because I want to at least go with Pro 2 cams
Old Sep 20, 2012 | 03:32 PM
snobordboy's Avatar
Moderator
Default Re: Prelude Build Question
With oversized valves and pro2 cams, I would look at a forged piston that will clear them well, either Mahles for stock block, or sleeve it and go for any choice of forged piston.
Old Sep 20, 2012 | 07:13 PM
nus_dogg's Avatar
Um. Skunk2 does not recommend you to run oversize valves when running Pro2 cams; otherwise, you'll experience V2V clearance issue.
Old Sep 21, 2012 | 02:09 PM
Yannx13's Avatar
I asked them and they said it was fine! That I just needed some higher compression pistons. To go at least 12.5:1 but 11.5:1 looks fine. I also saw TypeS could do the work instead of Mahle pistons. Any experience lived with one of thos two pistons, anyone?
Old Sep 21, 2012 | 06:25 PM
parthbla000's Avatar
^ im curious of this as well, i am looking to swap to Type S pistons on a relatively stock setup, unless theres a better OS piston to run on again, a mostly stock setup.
JDM_home
Jul 19, 2012 10:11 AM
kart_driver
26
Aug 31, 2010 01:07 PM
ALL MOTOR EF8
28
Jan 10, 2005 05:42 PM
sieger
Oct 10, 2002 08:38 PM
96SR-V
Jul 23, 2002 08:31 AM
