Obd1 Accord and Civic wiring similar?
Old Sep 20, 2012 | 02:11 AM
DDream's Avatar
Default Obd1 Accord and Civic wiring similar?
Im helping a friend with h22a swapped accord and i have wiring diagrams for obd1 civic
from what ive noticed so far is the ecu pinouts are basically the same but when
i look at the autozone engine wiring it shows the map sharing a ground with tps and other sensors not to mention it shows the wires going to some wierd pins
so i figured this couldnt be right...
just need to know if obd1 civic and accord wiring is somewhat similar for map tps egr eacv(basic sensors)
Old Sep 20, 2012 | 02:27 AM
DDream's Avatar
Default Re: Obd1 Accord and Civic wiring similar?
Also i dont care about colors of wires i only need to know if the Throttle angle sensor, egr,tw, share the same ecu ground?
and map is directly to ecu
BOMBCRU
Nov 24, 2004 01:14 AM
Audipwr1
Jun 20, 2003 02:59 PM
Katman
Nov 6, 2001 10:51 PM
