Fuel system/ bigger!! Will I need to get it retune?
Old Sep 19, 2012 | 10:08 AM
ja20_eg's Avatar
Default Fuel system/ bigger!! Will I need to get it retune?
I was woundering if I'll need to get my car re Dyno n tune with a bigger fuel pump system?? I was running a 255fuel pump with my set up!!!
Old Sep 19, 2012 | 10:37 AM
scmil95eg's Avatar
Default Re: Fuel system/ bigger!! Will I need to get it retune?
As long as you're not changing your injectors, no, you won't need a re-tune. If the injectors are the same size, you could run a 2000lb/hr fuel pump if you wanted, the injectors are still going to deliver the same amount of fuel. You'll just be circulating A TON of extra fuel.
If you change your injectors - you'd have to re-scale and/or re-tune the fuel map.
But if you're not changing your injectors, what's the point of upgrading your pump?
Old Sep 19, 2012 | 11:14 AM
ja20_eg's Avatar
Ok thanks!! Im still running my id1000 injector for now!!! Thanks for the info!
Evans-Tuning.com
Oct 4, 2010 07:08 PM
Evans-Tuning.com
Performance
12
Jun 1, 2009 05:04 PM
slamedcivic
Nov 2, 2006 02:49 PM
PTL
Jun 7, 2003 12:53 PM
