Help identifiying this Caliper!!!!!!
Hello, I need some help Identifying the rear drivers side caliper on my 89 crx. I believe that it is an integra caliper however im not sure. Here are some pictures and also would like to know what calipers i can use (civics?) since here in Costa Rica Parts are hard to source out. And lastly i would like to know if the caliper on the link below will work for my application. Ok thank you very much
[IMG]
[/IMG]
[IMG]
[/IMG]
The rear calipers are from a Integra 94-01 except the ITR.
"94-01 USDM Integra RS/LS/SE/GS/GSR (basically all trims except ITR) use the Nissin 17CL14VN front calipers and 7CLP13S rear calipers."
https://honda-tech.com/forums/suspension-brakes-54/jdm-itr-vs-usdm-gsr-calipers-2183754/ <- info can be found here. Good Luck!
https://honda-tech.com/forums/showthread.php?t=2183754 <- info can be found here. Good Luck!
prjct92eh2
Suspension & Brakes
29
May 6, 2010 03:56 PM
