how do you aim headlights?
my sisters headlight bulb went out on one side. so i took both out and replaced them with the stock, one side is higher than the other side. how do i aim them? she has a 2002 accord.
were they like that before? if not, you installed the bulbs incorrectly..
but anyhow..the adjustments for the headlights arent hard to find..there will be a slot in the back of the housing where you will see little teeth inside.. slide a philips head in there and turn.. there will be 2 adjusters on each side, one for up and down, one for left and right.. just pull the car onto a dark street, and use the street to adjust the lights, dont use a garage door until after, just incase they arent perfect..but use the ground to get the right beam pattern on the ground
pphan3
Apr 23, 2004 07:56 AM
