Problem!! 99 Accord Code P1399
Old Sep 18, 2012 | 01:00 PM
JENNY_EG6's Avatar
Default Problem!! 99 Accord Code P1399
Hi guys,
I have a 99 Honda Accord V6, my CEL was blinking as I was driving on the freeway and the car started to misfire and shakes as I accelerate. I looked up the code at first it was a MISFIRE in every cylinder and P1399 (Random Misfire). I changed cap, rotors, wire, spark plugs , but the problem is still there.
I know the accord has 1 ignition coil that goes into the dizzy, I changed that also but it didnt fix the problem. Car seems to be backfiring when you rev up to 2k RPM. When MAP sensor is disconnected, car drives normal. So i thought it was the map changed that, but same problem came back.
I'm really frustrated and can't think of anything else, would anyone be able to help or experienced the same problem?
Old Sep 18, 2012 | 04:20 PM
KaoticCO's Avatar
Default Re: Problem!! 99 Accord Code P1399
what kind of coil did you change to? check to see if any wires are loose on the dizzy
Old Sep 21, 2012 | 01:04 PM
JENNY_EG6's Avatar
I changed it with an OEM one. no wires are lose, Just changed cap rotors and wires today as well... didn't fix the problem.
Old Jul 24, 2013 | 10:11 PM
osageit's Avatar
Replace EGR VALVE, but first take intake manifold off, clean out EGR Port's (port on intake manifold, and port where EGR mounts) with carb cleaner. Then put new EGR on, then reassemble intake. I would also replace the knock sensor.
Old Jul 25, 2013 | 11:01 PM
holmesnmanny's Avatar
egr valves are built to last so don't change that until you've exhausted EVERY other option. If anything you can just clean it.
However, pull the egr valve connector and see how the car runs. Obviously this will throw an egr valve code but you just want to isolate the egr circuit. Does it run fine before the car warms up ?
bshaw
Oct 18, 2019 05:04 PM
Chaos1973
Jun 6, 2015 03:50 AM
shanepa2001
Nov 21, 2005 08:30 PM
BEE1
Oct 26, 2005 03:22 PM
Tomm11
Apr 26, 2003 01:25 PM
