FS: 00 Acura gsr 5 lug Tein 4700
Means of contact: pm
Price: $4700
Description:I have a 2000 acura gsr i am selling because i do not need two cars at the moment and i would like to have some extra cash. I will try to put down everything i know about the car.
145xxx miles on shell
Exterior:
Carbon fiber hood (both are faded)
Carbon fiber Trunk
Interior:
Very clean black interior
Rsx back seats
Ek front seats
Type r shift boot
Skunk2 shift ****
Suspension:
Tein type flex
Front and rear camber kit
Usdm 5 lug
jdm itr wheels
Motor:
Completly stock 94 usdm gsr
Everything is converted to obd2
using a obd1 ecu with s100 on a jumper harness
Stage 4 competetion clutch
8lb flywheel
Recent maintance:
New front wheel bearings
New ball joints
New front rotors
New front pads
Water pump
Timing belt
Cam shaft plug
Front seals
O-ring behind the dizzy
Rear main seal
Replaced trans fluid
Bad:
Unknown milage on motor
i dont have the ps bracket that goes on the head but i have the pump and all lines in good shape
cruise control is not working
ac needs re- charge
open header
check engine light- i dont have the air tempature sensor connected
abs light. all lines are there if you want to connect the abs
needs body work
Missing vtec sensor
Takes a couple trys to start and stay on drives good after
Pictures:
I have a red fender
Price: $4700
Exterior:
Carbon fiber Trunk
Interior:
Rsx back seats
Ek front seats
Type r shift boot
Skunk2 shift ****
Suspension:
Tein type flex
Usdm 5 lug
jdm itr wheels
Motor:
8lb flywheel
Recent maintance:
New ball joints
New front rotors
New front pads
Water pump
Timing belt
Cam shaft plug
Front seals
Rear main seal
Bad:
ac needs re- charge
open header
needs body work
Missing vtec sensor
Pictures:
I have a red fender
kmaz93da
Sep 14, 2011 09:25 PM
pearlwhitecrx
Northern California (Sales)
26
Jul 21, 2006 12:55 PM
