Are 225-50-15 drag radials too big for a stock h22?
Old Sep 18, 2012 | 04:52 AM
Eclectia's Avatar
Default Are 225-50-15 drag radials too big for a stock h22?
I have a 91 civic with a h22a, i was wondering if 225 drag radials would be good for my setup. Im using an exedy stage one organic clutch, is preloading the best way to go with this setup?
Old Sep 18, 2012 | 01:24 PM
TwinScrolled's Avatar
Default Re: Are 225-50-15 drag radials too big for a stock h22?
The 225's work, but look kinda goofy if you're gonna be driving it on the street with them. I run 205 MT ET streets as my street tires and throw on my slicks at the track. If you plan on only running the 225's at the track.. you should really just look into a set of 23" slicks. Drag radials help a little but got nothing on slicks. You'll be just fine if you preload.
Old Sep 18, 2012 | 01:33 PM
13173's Avatar
225's look far from goofy bolted to the front of a Honda. 205's drag radials in my opinion are a waste and I would get a full set of Nitto Neo Gen 205-50-15" instead. That way you can rotate tires if need be.
For your setup 225's would work, but me and some friends have had good results with just a set of Nitto Neo Gens. We can run mid 12's on regular old street tires with a stock K20A swapped EG hatch.
Also, the clutch you are using I used one of those years ago on a stock turbo B18C that made around 300whp and it held the power just fine while I had it in there. Don't ask me how, because I was surprised it was holding the power. It never slipped on the street or on the dyno during tuning.
Old Sep 27, 2012 | 08:14 AM
Eclectia's Avatar
Cool, thanks guys
CRXherbie91
Feb 18, 2013 05:07 PM
H22Stew
Feb 2, 2008 05:44 PM
H22A EG6
Dec 6, 2003 01:53 PM
Type R 702
Oct 20, 2001 11:57 AM
