Anyone have any experience with ARP wheel studs?
more here
http://www.honda-perf.org/pics/B18C1EG/eg/arp/
I heard these warp your hubs? Anyone know? thanks
[Modified by dyverge1, 6:11 AM 10/17/2002]
first question = yep...
second question = i have had no problems...
third question = i do
[Modified by TurboITR, 1:35 AM 10/17/2002]
thanks for the reply...how did you get them on the hubs...did you use the same method and just sort of push them in with the nut, washers, and impact wrench?
to use the ARP wheel studs.. u will have to drill the hub hole wit a 1/2 drill bit.. then the studs will go in normal, witout warping ur hub.. a lot of peoples try to press it in wit out drilling the hub.. and that is the result of thw warping... try that.. u'll be happy
