Transmission & Drivetrain Gearboxes, Differentials, Clutches
lightend flywheel oe clutch, or stage clutch and oe flywheel ????
Old Sep 17, 2012 | 03:12 PM
inda ceja's Avatar
Default lightend flywheel oe clutch, or stage clutch and oe flywheel ????
so im researching these performance products, and im running across this problem with lightend flywheels failing, and these are name brand like fidanza.
im running an ej8 with a n/a y8 with all the bolt on's
( skunk2 intake manny, c.a.i., ls throttle body, apexi ws2 full c/b, chipped ecu, and accel 300+ plug wires ).
i found an exedy oe clutch kit with 7 lb fidanza alum. flywheel, but im wearry of it from the reseach i've seen. so would it be beeter to run an exedy or clutch masters stage 1 clutch with oe flywheel, or oe clutch ( name brand ) with a lightend flywheel.
input will help.
$300 budget
Old Sep 17, 2012 | 03:52 PM
inda ceja's Avatar
Default Re: lightend flywheel oe clutch, or stage clutch and oe flywheel ????
bump
Old Sep 17, 2012 | 04:07 PM
inda ceja's Avatar
bump
Old Sep 18, 2012 | 05:56 AM
kyden's Avatar
what exactly is failing on the flywheel? i honestly would go with an exedy oem replacement clutch.
Old Sep 18, 2012 | 03:17 PM
inda ceja's Avatar
Alum. Flywheels , the teeth are coming loose, and spin freely. Where an oe fly wheel is solid.
I have a budget of 3 bills. There's a deal where you get an oe exedy clutch with a 7lb flywheel. But I'm setting mixed reviews on how they fail.
So would a staged clutch with an oe flywheel make a difference. Or just go oe on both? Exedy of course
Old Sep 18, 2012 | 08:11 PM
inda ceja's Avatar
ttt
Old Sep 19, 2012 | 07:17 AM
kyden's Avatar
i wouldn't bother with any "stage" clutch unless you're planning on forced induction. all the bolt ons in the world for a d series can't overpower the stock clutch.
i would buy a steel flywheel, such as competition clutch, if you want a lighter one than stock.
Old Sep 19, 2012 | 08:08 AM
inda ceja's Avatar
lighter steel? link or part #................... thanks for the info...
Old Sep 19, 2012 | 08:14 AM
kyden's Avatar
competition clutch has an 8.8lb steel flywheel.
Old Sep 19, 2012 | 11:19 AM
4drctr420's Avatar
Im just installed a fidanza flywheel and exedy oem clutch a few months ago into my 97 b18c5 and it was worth every cent. I'll admit I should have bought a stage 1 exedy for the type r, but in my 2002 civic dx Im at 320,000km on stock clutch, which Is exedy(daiken) so I wouldn't question the reliability of an exedy oem clutch on a naturally aspirated d-series, and the people who spin the teeth on fidanzas are usually a cause of high torque starters, or mad power
Old Sep 19, 2012 | 11:33 AM
inda ceja's Avatar
for like $20 more i found an Exedy oe clutch and Exedy raceing chromoly flywheel. ima going this route.
thanks guys for the 411
PWRDbyHseries
Mar 26, 2007 06:19 PM
jacky599r
Mar 17, 2007 07:15 PM
beandip
Nov 23, 2003 11:31 AM
Solipsist
Dec 6, 2002 11:49 AM
