Prelude build.
Alright, I dont know if this is the right thread but I just wanted to show you my progress with my build so far. I went a different route with this build. Took an f22b1 for fun and rebuilt it from top to bottom. so heres some pics.
**** I have a question for you all if you can answer I found this part and I don't remember where it goes... Had it with all the timing parts, but don't seem to need it haha..
##### Do you know what part this is??####
There is only one balance shaft, but yes, that goes over the balance shaft seal. They had a problem with these seals popping out and if that happens you have a huge oil leak.
If you hold it over the seal you'll see where the bolt hole lines up with a bolt that is already there. Take out the bolt and use it to hold that retainer in place.
boostedsol
Jan 1, 2005 06:05 PM
