Transmission & Drivetrain Gearboxes, Differentials, Clutches
91 CRX Si gearbox in 88 hatch??
Old Sep 16, 2012 | 11:43 AM
Jungle_88's Avatar
Default 91 CRX Si gearbox in 88 hatch??
I have a 88 hatch with a 4-speed trans I am wanting to put in a 5-speed I came across a 91 CRX si gearbox, wondering if this will be an easy swap and what might be needed?
Old Sep 16, 2012 | 07:55 PM
MR.johnson's Avatar
Default Re: 91 CRX Si gearbox in 88 hatch??
Yes, bolt in and go.
Old Sep 17, 2012 | 08:42 AM
Gearspeed-Performance's Avatar
Just make sure the clutch spline is the same because some have different spline count so you may need the proper clutch for the Si trans.
Old Sep 17, 2012 | 01:14 PM
94EG8's Avatar
Seagull Management
Yes it swaps, you will however need either a clutch disc for an '89 civic or you can go with a complete clutch kit for a '90 - '91 civic which uses a larger disc and flywheel (note that you need a flywheel for a '90 - '91 civic when doing this.
McGruber
Jan 17, 2011 09:07 AM
Lennart89
10
Dec 10, 2010 04:48 AM
Reason01
13
May 1, 2010 09:38 AM
anth9998
May 18, 2008 11:14 AM
wfocrx
Sep 24, 2006 10:46 PM
