I NEED TO KNOW WHAT THIS PART IS CALLED
Old Sep 15, 2012 | 12:15 PM
SkiZtheGoblin's Avatar
Default I NEED TO KNOW WHAT THIS PART IS CALLED
i got into an accident about a year ago and cant find the a certain part
(this is not my car but the same make and model)
That metal crossbar that is above the headlights and goes across the radiator.
Thanks if you can help out.
Old Sep 15, 2012 | 12:23 PM
athan21's Avatar
Default Re: I NEED TO KNOW WHAT THIS PART IS CALLED
rad. support
Old Sep 15, 2012 | 12:34 PM
mattf22b1's Avatar
Radiator support..this might help https://honda-tech.com/forums/paint-body-84/best-way-remove-radiator-support-3022699/
http://www.partsgeek.com/mparts/radi...ort/honda.html you can always try ebay aswell.
Old Sep 15, 2012 | 02:09 PM
BrotherAli's Avatar
Your going to want to get it welded back in. Another options is this:
http://www.harborfreight.com/4000-lb...ler-30329.html
http://www.harborfreight.com/1-ton-w...ing-44847.html
The rad support is very flimsy you can easily bend it back. It bent back the best by using the sides where the hole is rather than the top bar.
If your buying it look for a lkq or keystone store locally, all parts are way cheaper than even ebay. Think it was $40 vs $90 through ebay. There prices seem to be as cheap as my local pick and pull junkyard.
nihad
Nov 2, 2009 09:16 PM
ROTARY
Welding / Fabrication
15
Dec 2, 2007 09:49 AM
GeekinEK
Jan 29, 2007 10:48 AM
systemicchanges
Jan 1, 2007 05:35 PM
hondachris1994
Apr 1, 2006 06:36 PM
