Shifter won't come out of park, brake lights finicky
Old Sep 15, 2012 | 12:15 PM
oohtruck's Avatar
Icon2 Shifter won't come out of park, brake lights finicky
hey there party people,
I have a 2002 Honda Accord SE. My shifter wouldn't come out of park yesterday, and after some googling I figured out it was because of my brake lights not working. I used the little slot next to the shifter to get it out of park, so that's fine.
The general consensus seems to be it would either be the fuse, or the brake light switch. I checked the fuse, and it seemed to be fine. After driving some more though, I noticed that now the brake lights seem to be KIND OF working. Not all the time, but sometimes. Would this still possibly be the brake light switch? If so, is there a way to actually check the brake light switch to see if it's faulty? and lastly, I called my local Honda and they have a brake light switch for 44 bucks. Any suggestions where i can get it cheaper anywhere?
thanks!
Old Sep 15, 2012 | 02:14 PM
BrotherAli's Avatar
Default Re: Shifter won't come out of park, brake lights finicky
When you press your brake pedal do you hear a noise? There is a solenoid that allows you to go out of park which makes sure you are pressing your brake in order to go into reverse/drive, if its broken then you wont be able to go out of park.
Old Sep 15, 2012 | 06:25 PM
jdowen2's Avatar
004 36750-S84-003 SWITCH ASSY., STOP & CRUISE , SW, STOP & CRUISE $29.54 Each
Manchester Honda
Old Sep 16, 2012 | 07:40 AM
oohtruck's Avatar
no, don't hear a noise.
Old Sep 16, 2012 | 03:20 PM
Hidenplanvew's Avatar
Brake light switch, 20 bucks at checker with lifetime... Just replace it and stop guessing That is the problem and takes 10 mins to do
Old Sep 16, 2012 | 07:02 PM
oohtruck's Avatar
what is Checker?
Old Sep 17, 2012 | 04:34 AM
BrotherAli's Avatar
Then thats your problem it will need replacing. You will need the automatic transmission shift selonid.
Old Sep 17, 2012 | 08:46 AM
doctorbee's Avatar
what is Checker?
auto parts store
Joetxstate
Mar 4, 2020 05:37 AM
Xzay01
Lighting
Jun 14, 2013 08:53 AM
TomCurllyFry
Mar 25, 2013 09:29 PM
mysuperslowej1
Aug 1, 2012 07:09 AM
Project JDM CRX
Feb 7, 2007 05:00 PM
