Zc swap in..but
Old Oct 16, 2002 | 08:10 PM
Pcart's Avatar
Default Zc swap in..but
Im getting code 9 I checked everything out on the wires they seem fine I put a labscope on the m to get a signiture from the sensor..fine. Its supposed to be between 700-1000ohms checked out...The car is of course flat as hell from 3100 up because the inj are just firing for the hell of it. BUT I did notice that when Im under losd and the engine is flat my temp gauge goes nuts it bounces everywhere then as soon as Im of the throttle its cool again I ned some help Please all sugggestions welcome thanks
Old Oct 17, 2002 | 04:29 AM
USDM 4G VTEC's Avatar
Default Re: Zc swap in..but (Pcart)
if u get a code 9 (CYL sensor ) ... why dpont u invert the 2 cables of that sensor,... i had them switched and i had the code... and i wired them up like a ZC swap... anyways just try that to see if it works... it did to me!
Old Oct 17, 2002 | 05:51 AM
Pcart's Avatar
Default Re: Zc swap in..but (JDM EF9)
Ill try that again, I think I did that yesterday and still had the code. try it in a couple minutes.
Old Oct 17, 2002 | 05:59 AM
jlicrx's Avatar
are you wired right to the ecu - check your post under Hybrid
JapJunkie
Mar 22, 2004 11:05 AM
daniel89civ
12
Apr 6, 2003 05:36 PM
crxdohczc
Feb 19, 2003 06:31 PM
FBPninetynineEM1
Jul 26, 2002 06:32 AM
