Help! Which Harness OR combination of Harness' to use???
Old Sep 14, 2012 | 05:23 AM
Sosa0311's Avatar
Default Help! Which Harness OR combination of Harness' to use???
I'm stuck,I got everything I need for the lsvtec swap into an 89 si but I'm missing the engine harness =/ I've searched and even emailed a few sites to get answers but no clear answers.It's a b16 head from a 99 Si with a chipped p105 chrome "gold" ecu...I dont have any harness',will a jdm crx harness work?...Any info will be greatly appreciated.
Old Sep 14, 2012 | 05:45 AM
v4lu3s's Avatar
RTFM
Default Re: Help! Which Harness OR combination of Harness' to use???
you need an 88-91 si harness.
the jdm harness will work in a jdm crx OR it will work in a car that has been completely converted to right hand drive jdmness.
Old Sep 14, 2012 | 09:52 AM
Sosa0311's Avatar
Sweet,thank you.I will need to wire VTEC,correct?Or simply have a shop make one using the existing harness.? The car has a sohc zc (thats how I picked it up).Sorry for all the ?'s,I'm a lost one when it comes to wiring =/
Old Sep 14, 2012 | 10:41 AM
crx_si-r's Avatar
there is no such thing as an 88-91 si harness. there is 88 si and 89-91 si. OP you need a harness that matches your body harness. in your case you need an 89-91 si harness. once you have that you can do the proper vtec mods/additions and wiring to ecu (obd0, obd1 or obd2 what ever you choose).
if you need one lmk i can make you one to match your set up.
9165415266
Old Sep 14, 2012 | 04:57 PM
Undrboost's Avatar
ive found that the 88 and the 89 are specific to the years and the 90-91 are interchangeable but as a rule of thumb always use the engine harness that goes to the car and just modify it to work with the engine ie splice and put the connectors on it. best way to do it imo.
Old Sep 14, 2012 | 06:02 PM
crx_si-r's Avatar
Wrong. Only 88 is different, 89-91 are exactly the same engine harness. Body harnesses are different.
I've built many stock replacement and swap harnesses. And they are only 88 and 89-91 specific
Old Sep 14, 2012 | 10:15 PM
xxOldschoolxx's Avatar
^^ seen your work brother. Good stuff.
Old Sep 15, 2012 | 06:05 AM
crx_si-r's Avatar
^^^^^thanks
Old Sep 15, 2012 | 11:14 AM
Rice_Bowl's Avatar
sorry to jack thread but i needed help on harness too.... if i was to use an obd2 dizzy with obd2 to obd0 wire harness and running a obd1 ecu on my ef and i already got the obd0-obd1 ecu pig tail, will it work or what do i need to do????
ikaika3269
10
Feb 26, 2008 06:25 PM
exist12
Oct 26, 2007 08:19 AM
Ryan562
Jan 17, 2007 05:31 PM
91H4hatch
Sep 8, 2006 08:14 PM
Crimson_Tide
Jun 30, 2005 12:23 PM
