Hondata s300 and TDC
Old Sep 14, 2012 | 02:43 AM
JDM97R's Avatar
Icon2 Hondata s300 and TDC
Hi,
I have a problem on my S300
I am checking the crank pulley with the timing light and I m finding 2deg btdc
I checked all timing marks and cam degree
When I add timing from the tables ,I can see the 16 deg on the pulley marks
Is there something I have to do in the calibration please?
Thanks
Old Sep 14, 2012 | 05:23 AM
surfingsk8r's Avatar
Default Re: Hondata s300 and TDC
Hondata has an option to lock the timing just for setting the base timing, I cant remember where but if you look in the drop down menu's at the top of the screen you will see something that says set ignition timing or something similar to that. click that and then adjust the distributor until everything lines up with the timing light then your done.
Old Sep 14, 2012 | 06:47 AM
snobordboy's Avatar
Moderator
Yup, it is in the Online tab at the top, when you select that line, it locks timing in the ecu, so you can set your timing. just adjust the value to what you want to match, and line it up. once done click close, and your timing is set.
trinib20
Dec 29, 2014 06:33 AM
JDMtype Eg6
Sep 3, 2008 05:14 AM
brokenojoke
Engine Management and Tuning
Jun 14, 2008 09:50 PM
Jorsher
Oct 24, 2004 04:51 AM
GReddy SI
Sep 8, 2004 01:25 AM
