My Subwoofer enclosure
Old Oct 16, 2002 | 07:45 PM
MJ23FE's Avatar
Default My Subwoofer enclosure
Nothing special but it bumps very nicely with the 600+wRMS my 500a2 pumps into it. The only reason why i have the back seat folded down and the subs faced into the cabin was because it was the middle of Spring and i wanted to hear the difference, i like the way they sound when faced back into the trunk, better SQ because the bass is not so over powering!
[Modified by MJ23FE, 11:52 PM 10/16/2002]
[Modified by MJ23FE, 11:53 PM 10/16/2002]
Old Oct 16, 2002 | 07:50 PM
poison's Avatar
Default Re: My Subwoofer enclosure (MJ23FE)
Old Oct 16, 2002 | 07:55 PM
MJ23FE's Avatar
Default Re: My Subwoofer enclosure (poison)
Thanks poison! I was having some technical difficulty!
[Modified by MJ23FE, 11:56 PM 10/16/2002]
Old Oct 17, 2002 | 08:41 PM
ku09's Avatar
nice setup!
Old Oct 17, 2002 | 08:48 PM
MJ23FE's Avatar
Default Re: My Subwoofer enclosure (ku09)
thanks man!
Old Oct 18, 2002 | 09:34 AM
cd5_2NR's Avatar
nice set up..have you tried facing them the other way..im sure your bass will hit harder...!!!
Old Oct 18, 2002 | 09:38 AM
MJ23FE's Avatar
Default Re: My Subwoofer enclosure (DRAG_ZERYONsi)
I was experimenting with them when i had it faced into the cabin as you see in the picture. I had it that for about a week to just see which direction sounded better. It definately sounds better faced toward the rear. When faced toward the cabin its blocked by the rear seat and the air does not have any room to travel. The clear coat on my trunk is peeling off due to the bass pressure. If i am wrong, does anyone else know of any reason for the clear coat to peel off??? It's only happening on the trunk and is not exposed to anything that would make it happen.
Old Oct 18, 2002 | 02:10 PM
MJ23FE's Avatar
Here is my headunit if anyone really cares to see!
Young_R
Oct 16, 2002 04:49 PM
ItJustLooksFast
Aug 16, 2002 01:18 AM
