FS: LC1 + SSI4
Bought them both a few years back, they've sat in their original boxes since. I started on a harness for the SSI4 that I can include as well. They have never been installed let alone used. O2 sensor still has the original lube applied the thread from factory. I'm also throwing in a Denso MAP sensor to datalog via boost pressure modified by Karl (scarecrowx) to 5 bar(?), as well as a serial->USB adapter (chinese made, didn't come with a driver and you'll have to search online to find the right drivers for your operating system)
Does not come with a gauge as I was primarily going to use this to datalog with on my laptop, hence the SSI4. If you must have a gauge, you can find the innovate DB/MTX/et cetera on ebay. Can also wire in a $10 LED display, linked at the bottom.
Selling together:
Priced $5 cheaper than ebay bundles that don't include any extras. So $235 shipped to the lower 48 states. Will not separate at this time.
LINK to wideband DIY LED: $13 LED Display
Selling together:
cbustuner
Nov 9, 2007 12:06 AM
