TW 94 Civic CX hb, clean vitara turbo NO Cheap ebay parts!
> Year: 1994
> Make: Honda
> Model: CX Hatchback
> Motor: D16z6 1.6L single over head cam
> Head: Port and polished, ZEX 59300 race cam, skunk2 titanium retainers, skunk2 valve springs, bronze valve guides, skunk2 intake manifold, 72mm race throttle body, speed factory intake manifold gasket, ngk bkr73 cold plugs, ngk blue plug wires, hasport mounts, golden eagle fuel injector rail and apr head studs.
> Block: Eagle H-beam rods, apr rod bolts, vitara 75.5mm piston and rings, polished crank, acl race bearings, oem head gasket.
Trans: 95 ex 5spd, clutchmasters stage 5 clutch kit, stock lightened flywheel.
> All machine work was done by a Lee Autoparts machine shop. Everything was balanced also. New gaskets from top to bottom, dual core race radiator, slim fan, new thermostat was also put in.
> Custom Turbo kit: Precision PT5858 turbo, Tial Q bov, Precision Wastegate, Go-autoworks mini ram turbo manifold, Go-autoworks 3 in downpipe, go-autoworks dupe tube, go-autoworks stealth oil line kit, 2.50 intercooler piping, large race intercooler
> 15" Rota lightweight race wheels, new low profile tires, drilled and slotted rotors, acura integra gsr disc brake set up, tein race springs. running 10psi on crome p28 ecu, golden eagle vac kit.
> Installation of the motor and misc parts where done by One6 motorsports in Elk Grove, IL
Clean title, body is in great shape no rust on quarter panels. New black housing headlamps, amber vision corner lamps, new fenders added. Everything was just done about 4 months ago. Car idles great and pulls hard. Barely driven and well taken care of.
Taking offers....
Just had a baby need to sell for something 4 door.
Please no low ballin, no cheap eBay stuff. Runs like a champ a lot of potential.
> Make: Honda
> Model: CX Hatchback
Taking offers....
No marking on it. I purchased it from www.go-autoworks.com, and it's the mini ram set up.
I know this is just TW, but if you want to part any of the motor out I would be interested in engine parts or the whole engine itself. I currently have a d16y8 turbo on stock motor, I want a built motor.
