Turbo Del Sol B16 dies under "load"
Old Sep 13, 2012 | 07:57 AM
West Werks's Avatar
Default Turbo Del Sol B16 dies under "load"
Long story short,
I have a buddy with a built B16 turbo Del Sol and every time he is driving and comes to a stop or an idle, and the radiator fan comes on, or he rolls his windows down or turns on the headlights, the engine stalls. Idle is set at 900-1000rpm.
He has changed out nearly the entire charging system, from the battery, fuse box, alternator, to a different engine wire harness, still the same thing.
We have changed out the thermostat, temp sensor, IACV, TPS.
We have tried a stock P28 ECU, different from his Hondata S100, still the same thing. We have had two different tunes by both Church and Bisi. He has replaced all of his engine/chassis grounds. He has sanded down all the points of contacts for the grounds to bare metal, nothing has changed nor helped the situation.
Only thing we haven't tried is a different throttle body and different distributor.
Anyone ever seen this or have first hand experience with something like this?
TIA
kirkfreeman
11
Apr 4, 2015 09:31 AM
delsol88
Aug 9, 2012 11:39 PM
z0mby
17
Dec 5, 2011 09:23 AM
Jdcamaros
Apr 17, 2011 10:27 AM
delsol6386
Apr 16, 2004 06:27 AM
