Mid-Atlantic (Sales) VA, DC, and MD
FS: 2000 EM1 EBP tuned, very quick
Old Sep 12, 2012 | 04:47 PM
awood202's Avatar
Default FS: 2000 EM1 EBP tuned, very quick
B16B head/b20 block LS/Vtec 84MM bore, .030" thick
Mileage on body roughly 130,xxx, odometer was changed(it says 180xxx), motor purchased through JE Import Performance has roughly 60xxx (pulls very hard)
CTR transmission and tuned on Hondata s100 ecu at 195whp/140wtq
Private Label 4 to 1 Header
Password JDM Whale PP intake
NGK Iridium IX spark plugs
NGK ignition wires
Password JDM Intake Mani gasket
New fuel filter
some custom drivers mount, very stiff ride but good quality
US type R valve cover
Always use Mobil1 full syn 5w30 Mobil Oil filter.
no leaks or knocks
Recently replaced O2 sensor
Greddy exhaust tip
Trans:
stock CTR LSD trans.
both side axles are brand new
not sure which clutch or flywheel but work fine and grabs hard
no grinds, pulls great
Suspension/brakes:
Omni coilovers with Koni struts.
Rear blox sway bar links
Brembo rotors and brake pads
Skunk 2 front and rear strut bars, lower tie bar
Extended lugs Skunk 2 lug nuts
Interior:
Stock Si cluster
LS front seats, stock si rear seats
Kenwood radio
Infinity front speakers
Exterior:
30% tints all the way around
GSR blades
Things that I would change:
Rotors are warped (ill get it done if its not sold by the end of Oct.)
Tints are a little bit scuffed
Front right and left fenders were repainted before I got the car, its barely noticeable unless you are looking for iminor dent on drivers side door
Oil has been changed regularly. All motor work done by JE Import Performance (receipts provided)
Asking price: $7000 or best offer takes it.
Stupid people with stupid prices will be ignored, but make offers anyway
Call or text 2026418485 (you can inbox me, but I dont check here regularly.)
I may have missed something just ask if you have questions.
Old Sep 13, 2012 | 05:12 AM
Modell's Avatar
Default Re: FS: 2000 EM1 EBP tuned, very quick
Came in to see pics...great looking car!
GLWS!
Old Sep 17, 2012 | 06:57 PM
awood202's Avatar
bumpy johnson
Thanks btw
Old Sep 18, 2012 | 04:03 AM
em_1LOVE's Avatar
What does this run in a 1/4.. I wanna do a legit build like this but never have seen a legit lsv... Bump though on the car looks clean I love the blades on a si
Old Sep 19, 2012 | 06:58 PM
lees29's Avatar
Just curious, did you have to cut the oem radiator fan for that private label header? Bump!
Old Sep 21, 2012 | 04:00 PM
awood202's Avatar
I haven't taken it to the track yet....I went once and it started to rain, so that must have been fate. But im assuming it would run mid-high 13s with slicks. But, i'll never know until I take it.
someone make an offer...****
Old Sep 21, 2012 | 07:44 PM
AllMotorRP's Avatar
Like the build, love em1's on blades...
Bump glws
Old Sep 21, 2012 | 08:47 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
5800
Old Sep 23, 2012 | 01:46 PM
awood202's Avatar
Bump glws
thanks man. I appreciate it. bumpy johnson
Old Sep 26, 2012 | 11:14 AM
awood202's Avatar
No, i believe it was relocated to the left. This was all done before I purchased the car.
gloria2323
Northeast (Sales)
14
Jan 19, 2015 06:38 PM
THMotorsports
Jul 17, 2006 10:38 AM
THMotorsports
Jun 21, 2006 06:34 AM
THMotorsports
May 19, 2006 02:04 PM
