1999 Honda Accord LX (Cutting Off)
Guys really could use some help with this one! Car was cutting off when hot outside, CHANGED THE MAIN RELAY. Things were fine until here recently, started cutting off again and just turning over. I can still here the fuel pump hummmm when I turn on the key, but the engine will just turn over, over, and over. Then thing will crank when it decides it wants to (30 - 60 mins later). Went to auto store had battery, alternator, and starter checked out. Battery was bad, got it replaced and the car cut off the following day. Guys any info will be greatly appreciated because I'm thinking about changing the fuel pump!
has the ignition switch recall been taken care of? dealer said they did on mines but I found that my old alarm was still hooked up when I took it apart.
replacement with an autozone duralast lifetime warranty part was successful, no more stalling and this annoying problem:
had the SAME problem in my 99 ex, it was The CrankSensor, but honda did have a Recall on these years for the Ignition "switch" and the "Harness"..
My car would run fine and just Die, all electrical systems were good, i would go get a Diagnostic and see if it throws any codes
acidburn2k2
Mar 10, 2017 08:58 PM
kalvarez09
May 28, 2011 07:35 AM
