Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
8th generation rear lip spoiler template
Old Sep 10, 2012 | 03:56 PM
stockvtec1's Avatar
Default 8th generation rear lip spoiler template
Hi fellow members, I am trying to find installation instructions or a drilling template for the OEM civic sedan trunk lid spoiler that I believe came stock on the 2008-2010 models.
I have a 2006 and I picked up a used spoiler. (small lip style, not the wing)
Any help would be appreciated.
Thank you.
Old Sep 10, 2012 | 05:40 PM
m_shake's Avatar
Default Re: 8th generation rear lip spoiler template
If it came stock, NOT a Honda accessory then there is no template because trunk is predrilled for it. Should post a pic of said wing.
Old Sep 10, 2012 | 06:00 PM
stockvtec1's Avatar
Im not really sure if it was an accessory at all, maybe just stock on certain years. Here is which one I am referring to.
http://www.8thcivic.com/forums/insid...p-spoiler.html
The one on the dark grey
Old Sep 11, 2012 | 03:56 AM
97emsedan's Avatar
If there are holes for the screws to go into, take a small piece of crayon ( you can remove this easily if it gets jammed into the hole) and put it into each screw hole you see, and make sure it protrudes from the hole. MAKE SURE YOU REMOVE THE TRUNK LID LINER BEFORE YOU DRILL! Place the spoiler onto the trunk lid as you would see it when it is mounted and give it a good amount of downward pressure to make the crayons mark their locations. Take another crayon and note the edges of the spoiler, top and bottom as well as the sides, this will locate the spoiler exactly if you have to redo the first step. Remove the spoiler and note the locations of the marks, then verify the screw holes are clear. Ensure they are clean as you will want to apply a small amount of Loc-tite blue thread locking compound to the screws when you fasten the spoiler down Drill the holes and de-burr the edges. Apply a small amount of silicone to the drilled hole edges ( to prevent rusting) and place the spoiler on the trunk ( after you pop the trunk of course!). Loc-tite your screws and tighten them down. You might want to find some nylon or fibre washers to prevent the screws from scratching the paint on the inside of the trunk lid. Replace the liner and you are done.
teggrl
Mar 16, 2010 03:00 PM
d16lxciv
May 23, 2008 04:38 AM
watisjdm
Jun 15, 2007 12:48 PM
chansaephanh
Jan 12, 2007 10:37 AM
mildly.interesting
Dec 14, 2004 12:51 PM
