jdm type r non srs steering wheel
if its from a JDM Civic Type R (CTR) then yes it will work
ift its from Teg (ITR) then it will not work as the hubs are not compatible with 96+ civics and 02 RSXs
How much do those cost they are nice. And i want one without the airbag.
[Modified by WanTing, 8:08 PM 10/16/2002]
jdm ITR fits EG's.
jdm CTR fits EK's.
however, i have seen a pic of a JDM non-srs ITR wheel on a 96+ civic..
if someone can figure that out..i would appreciate it
jdm CTR fits EK's.
I believe CTR wheel ( the bottom one)all come with airbag. I got my $475+shipping.
Where did you buy it from? That is a really good price
jdm ITR fits EG's.
jdm CTR fits EK's.
jdm CTR fits EK's.
and why does a USDM ITR not fit ? (or im i missing somthing ?)
we have the ITR here 2 from 98<
so should that fit my 95 SI HB ?
there is a non srs ctr wheel whcih looks identical to the non srs itr.. just diff. hubs
i had this problem i got hte itr one and doesnt werk in the ej8
jdmpartz.com has a picture of a jdm ctr non srs wheel.. but it's the same pic they used for the jdm ITR non srs
i've heard about this too.. but i've never seen one.
It is the same wheel, but the hub is different, I think this came in 96-98 ? ctr's
Hey INFINKC what's that tinted area where the air vent is suppose to be on the left side?? looks like there is gauge of some sort?? what's in there??
infinkc
Why is your AC and stuff different?? Does the black wheel go well with the gray dash? How much was your wheel if you dont mind me asking?
ok first- When i got my wheel it was from an itr. What i did was swap the entire steering column with a 94- integra one. (got it from a local wrecking yard)
You also need the plastic pieces that goes around the ignition switch and the controls.
It didnt take that long to change out the column, its only like 4 bolts if i remember right. The civic ignition switch will bolt right onto the teg column. Looks good cause the plastic covers are black also, no more gray.
think i paid like 200 for the wheel.
second- i cut out my ac vent and put a oil pressure and air/fuel gauge behind smoked plexi glass. Took it out for the summer havent put it back in. (needed the extra vent for air-condition
[Modified by infinkc, 4:06 PM 10/17/2002]
)[Modified by infinkc, 4:06 PM 10/17/2002]
