185/75/14s on a 1994 civic 4dr
Old Sep 10, 2012 | 11:42 AM
bgc's Avatar
bgc
Icon2 185/75/14s on a 1994 civic 4dr
Aside from the speedometer and odometer error (about -10%), and buying some 14" rims, can I put 185/75/14s on my civic? It has the standard 175/70/13s. The 14s are snows from a different car that were expensive and still in new condition.
Thanks!
Old Sep 10, 2012 | 03:21 PM
redm3turbo's Avatar
Default Re: 185/75/14s on a 1994 civic 4dr
yep, you can run em. they are going to fill up the wheel well though. hope you aren't lowered
my snows are 70's series...I like them.
Old Sep 10, 2012 | 05:48 PM
bgc's Avatar
bgc
Thanks for your reply. Nothing modded on my car. The wheel wells look empty, so as long as they'll clear then that's great.
Old Sep 10, 2012 | 06:21 PM
jbpnoman's Avatar
http://www.1010tires.com/tiresizecalculator.asp
195/75R14 will severely limit your tire options. Use the calculator I linked, do some playing, and find something that'll fit and give you plenty of good options. As long as you stick with a stock offset, you can safely go as high as 195 (and possibly 205, if you can find a tire in the correct size) without worrying about scrubbing.
If you want to fill out the wheel well, putting obscenely large tires on your car isn't the right way to do it.
Old Sep 10, 2012 | 07:19 PM
bgc's Avatar
bgc
Thanks to you too. The tires are only 185, and not a mod choice, just an expensive set of snow tires from a GM car I got rid of. This is strictly about utility and frugality.
My car is teal with a gold pinstripe so I am definitely not going to sweat about esthetics.
Cheers.
MANualBoy
Feb 25, 2014 10:30 PM
Powered by Honda
12
Aug 4, 2005 04:47 AM
charjacq
12
May 6, 2004 10:03 PM
DSPDA3
Mar 23, 2004 09:01 AM
neumonik
16
Nov 17, 2003 10:59 AM
