how to check if speedo cable is working or broken?
Old Sep 10, 2012 | 09:51 AM
GPC91's Avatar
Default how to check if speedo cable is working or broken?
ok i replaced me transmission a few weeks ago and when i dropped my old one i forgot to take out the speedo cable and then when i let the trans down it caught and yanked out. i think i messed up the tip since now my speedo doesnt work and im getting code 17 (obd1). so im 95% sure this is my problem. but just checking bacause i have seen on other threads saying to check it because it could be the sender in the cluster that is bad
Old Sep 10, 2012 | 09:57 AM
slywfbpsi's Avatar
Default Re: how to check if speedo cable is working or broken?
Working? See if you MPH increase as you drive or if your mph gauge shakes around 20-35 mph and then "Catches" back up
Broken? Take the cable out of the tranny, pull on the cable, if half of it pulls out, but it's still connected to the gauge...
Sender? Swap out the cluster, if it works with no CEL, then it was the sender.
Old Sep 10, 2012 | 10:27 AM
24TEN's Avatar
PHANTOM MENACE
I did this just a few weeks ago myself, plug stayed connected to the back side of the cluster but the cable came out when I dropped my transmission. Simple fix, put it back. Hope yours is as easy of a fix.
Old Sep 10, 2012 | 10:46 AM
GPC91's Avatar
ok i think its the cable. i looked at it and i think then end part is bend slightly and that would make sense for why it seems like it wouldnt go into the trans far enough. and my cluster when i first started after i swaped trans would bounce up to 5 or 10 mph sometimes then just go back to zero. i know it was kinda a noob question but just wanted to get a few second opinions before i replaced it. and it runs without a code untill i start coasting in gear. does this sound weird to anyone but me?
Old Sep 10, 2012 | 07:42 PM
dickdragon's Avatar
Won't go into gear cuz of the speedo cable? Did u install the clip back on so that the cable goes in only so far?
Old Sep 11, 2012 | 08:48 AM
AGREENCRX's Avatar
17's a vss code, More than likely it needs replaced. around $30 for a new one from the parts store.
Old Sep 11, 2012 | 10:24 AM
GPC91's Avatar
i didnt even notice a clip when i took it out. so that could be my problem. is there any way to test my cable to see if its just the clip or if my cable is actually broken.
Old Sep 11, 2012 | 10:59 AM
LoveDeezNutz's Avatar
Check the clip or cluster to see if its still in.
Old Sep 11, 2012 | 11:23 AM
GPC91's Avatar
there is no clip i know that the cable is not in the transmission. i am just looking to see if there is any way to see if the cable still works without that clip to put it in the trans.
Old Sep 11, 2012 | 11:44 AM
TearSDMF89dx's Avatar
yeah a cordless drill spin it and have someone watch your speedo ... i mean seriously its a f*cking cable that spins in a sleeve how hard is that to diagnose a bad one? both ends are easily accessible with less than basic hand tools .... you just wasted time you could've spent on something productive
Old Sep 12, 2012 | 04:49 AM
dickdragon's Avatar
A u shaped cliP that resides in the fat part of the connection boot. Where the vss cable meets trans.
Old Sep 12, 2012 | 07:33 AM
hypforlife32's Avatar
Without that clip it will wiggle loose over time or may not sit tight against the trans. This happened to me one time.
GPC91
Sep 17, 2012 01:11 PM
Barry116
Feb 8, 2012 07:41 AM
dusterbd13
Oct 19, 2009 06:47 PM
shai x boi racer
Jul 14, 2005 04:52 PM
rasta420
Aug 26, 2002 04:25 PM
