For Sale - 1995 Del Sol Si LS/Vtec Turbo
1995 Honda Del Sol Si
Location - Lakeland, Fl
Contact - Vance @ 863-604-2139
Price: 7500 obo
***If you wish to purchase the chasis or complete engine/turbo swap that is an option.
This car was about a 12month project worked on by me in the garage in the evening and on weekends as time and money permitted, most items were purchased new by me with receipts for proof. At this time there are 100k original miles on the chasis and under 10k on the engine. The engine/turbo system was tuned once once on 8/18/07 by Pherable.net (John Vega) and has run flawless ever since.
All power accessories function as they should. Including power steering and cruise control. There are no oil leaks, no coolant leaks, or funny noises.
I purchased the car completely stock on 3/31/2006 with 89,xxx miles on the original odometer. Always a Florida car with absolutely no rust.
The instrument cluster indicates good operating temperature, good idle, no check engine lights, good idle afr on the wideband, and a healthy engine with 22inches of vacuum at idle.
Interior
Window Tint
AEM Uego wideband
Apexi boost gauge
B&M pro shifter
ITR shift ****
ITR shift boot
Sony cd player
Boston and Alpine speakers
Exterior
16" Rota GT3
New Falken 452 tires (215/40/16)
1piece headlights with Silverstar bulbs
Nokya yellow AUX bulbs
EG front lip
Suspension
Drop Zone struts and coilover sleeves
Omni Power adjustable front control arms
ITR front strut bar
Rear VTEC sway bar and lca's
Drilled rotors
Akebono PRO AC+ brake pads
Engine
B18B shortblock
81.5mm CP pistons & rings - blue printed
EAGLE forged rods
OEM bearings blue printed (main & rod)
Canton Mecca catch can & fittings
Decked .001 for straightness
New OEM ITR timing belt
New OEM ITRwater pump
New OEM ITR oil pump
Prothane motor mount insert (3)
B16 cylinder head
CC'd and polished combustion camber
Ferrea stainless valves
Bronze valve guides
ITR valve springs
Crower chromoly retainers
98 spec ITR cams
Edelbrock Victor X manifold - ported & powder coated
King Motorsports OEM ITR bored to 65mm throttle body
SKUNK2 Pro series cam gears
Powder coated JDM valve cover
King Motorsport manifold studs
TRANSMISSION
B16 1-4 with LS 5th
SPOON LSD
Competition Clutch stage 4
NEW oem axles
ACT 12lb flywheel
Brand new OEM Del Sol shift linkage
TURBO
INLINE PRO SS t-3 manifold
Turbonetics 63ar stage 3 turbine, 70ar compressor = aprx 54trim
3" downpipe and 3" SS exhaust
2.5" intercooler piping w t-bolt clamps
Spearco intercooler
ECTune by Phearable.net (street & dyno)
GM 3bar map sensor
Tial wastegate merged into downpipe
Turbonetics Evolution bov
FUEL
Walbro 255lph HP
Aeromotive fpr, with water filled gauge
Braided fuel lines with AN fittings
STR fuel rail
Precision 780 injectors
OEM injector driver plug and play
Price: 7500 obo
Interior
Window Tint
AEM Uego wideband
Apexi boost gauge
B&M pro shifter
ITR shift ****
ITR shift boot
Sony cd player
Exterior
16" Rota GT3
EG front lip
Suspension
ITR front strut bar
Drilled rotors
Engine
B18B shortblock
EAGLE forged rods
B16 cylinder head
Bronze valve guides
ITR valve springs
98 spec ITR cams
TRANSMISSION
B16 1-4 with LS 5th
SPOON LSD
NEW oem axles
ACT 12lb flywheel
TURBO
Spearco intercooler
GM 3bar map sensor
FUEL
Walbro 255lph HP
STR fuel rail
