Will stock Itr axleback exhaust fit a apexi n1 piping?
Old Sep 9, 2012 | 10:12 AM
itr_alexx's Avatar
Default Will stock Itr axleback exhaust fit a apexi n1 piping?
Hey guys It's been awhile since I've been on here but I just have a quick question. I'm not sure if anyone here has done/try, but will the stock axleback exhaust fit with the piping of the apexi n1 piping? The reason why I am asking is I have a hole in the n1 muffler that is beyond repairable. Instead of shelling out $500+ I was going to trying to figure out if I will run into problems such as if the flange will not match up or the piping would be too long etc.
Thanks
Old Sep 9, 2012 | 12:03 PM
racebum's Avatar
Default Re: Will stock Itr axleback exhaust fit a apexi n1 piping?
i would just weld your muffler of choice on to the piping you have. cut right at the muffler, get it lined up and reweld.
as for if what you said fits? jack it up and try it. very easy to pull apart
Old Sep 9, 2012 | 03:15 PM
allyourapex's Avatar
I did this on my 97 and it lined up fine. Wanted to quiet it down for daily driving.
Old Sep 9, 2012 | 06:18 PM
itr_alexx's Avatar
Thanks for the input guys. Allyourapex, so you bolted on your stock muffler to the apex'i n1 piping with no problems?
Old Sep 9, 2012 | 06:24 PM
wego5typer#431's Avatar
Racebum's recommendation is your best bet, but to answer your question, yes it will fit.
I purchased my car with this exact configuration. The Itr axleback will not fit exactly as it is setup for a donut gasket & the n1 piping is a flat faced flange. Mine had a flange gasket sandwiched between the two & it worked fine with no leaks.
Old Sep 10, 2012 | 11:25 PM
Yup no problems.
Also used a donut gasket with no issues.
Old Sep 11, 2012 | 05:00 AM
itr_alexx's Avatar
Thanks everybody. I will be attempting the fix this weekend.
Old Sep 11, 2012 | 08:29 AM
SpoonREVS's Avatar
I have a apexi N1 that i would be selling as soon i find the muffle i want ! looking for a world sport or NUR
jjaskula1
Sep 12, 2005 03:28 PM
Monkey Z.
Aug 3, 2005 07:36 PM
MrCivic98
Jan 18, 2004 10:38 AM
sjteg
Dec 16, 2002 10:23 PM
eg6madness
Sep 9, 2002 08:07 PM
