LS VTEC Timing Cover Options
Old Sep 9, 2012 | 07:08 AM
EthanolSTi's Avatar
Default LS VTEC Timing Cover Options
Hey all. I finally decided to register after skimming the forums the past fee weeks. I've searched and searched, finding inconsistent information on what will and what won't work for timing belt covers on LS VTEC setups. The head is a B16A2 off a 1999 Civic Si. Does anyone have a timing cover on their LS VTEC, knowing what actually works and what doesn't?
Old Sep 10, 2012 | 07:02 AM
kyden's Avatar
Default Re: LS VTEC Timing Cover Options
nothing oem works on the inner cover. you'll have to trim some of the nubs on the back until it fits.
Old Sep 10, 2012 | 09:17 AM
EthanolSTi's Avatar
I assume you're reffering to "number 7" in the following picture?
From what I've gathered, number 7 is the inner upper timing belt cover, number 3 is the outer upper timing belt cover, and number 1 being the middle timing belt cover? The consensus for the lower piece of the timing belt covers seems to be based off of block/oil pump combination, as seen here.
Old Sep 10, 2012 | 09:34 AM
kyden's Avatar
correct, #7. the lower cover, #1 depends on the oil pump, doesn't matter on the block as they are all the same for the same given year.
Old Sep 14, 2012 | 10:07 AM
EthanolSTi's Avatar
Here's the piece I'm looking for:
nowayintegra14
Dec 2, 2010 02:21 PM
92integraVTECgsr
May 25, 2008 07:04 AM
85mm LS VTEC
Aug 4, 2004 02:18 PM
noble4ws
Nov 11, 2003 05:27 AM
