CEL 7 & 17 but speedometer is funtioning
Old Sep 8, 2012 | 02:07 PM
stickman78114's Avatar
Default CEL 7 & 17 but speedometer is funtioning
91 si w/a z6, converted to obd1. getting codes 7 & 17 but my speedometer is reading on cluster.
i replaced the intake mani and TB in and attempt to get rid of code 7 and upgrade from the a6 intake mainifold. came from a running z6.
still receiving both codes.
running a p28 ecu.
any ideas?
Old Sep 8, 2012 | 09:16 PM
DDream's Avatar
Default Re: CEL 7 & 17 but speedometer is funtioning
Have you tried Resetting?
I never did it but im pretty sure you have to calibrate TPS
Your Vehicle speed on cluster is driven by cable the code your getting is the Electronic one that is in tranny and goes to ECU
Old Sep 9, 2012 | 01:56 PM
yeah i've tried ressetting the ecu
i thought you only have to calibrate the TPS if it is replaced or removed
which sensor is this? i'm using the stock ef si cable tranny. it was my understanding that the ecu gets its speed info from the cluster itself.
Old Sep 9, 2012 | 05:20 PM
Former User's Avatar
How are you resetting the ECU?
Old Sep 10, 2012 | 09:20 AM
video_voide's Avatar
I have a similar issue, but just getting code 17. I'm using the L3 transmission and I believe the clip which holds the cable in the gear mechanism is not securely keeping the cable in place. Intermittently the cable may be floating up out of the gear in the trans a little, especially under quick acceleration. My speedo is working, too. The L3 has no electronic sensor just gears. The sensor is behind the speedometer. I hope to get a fresh clip and see if that helps.
SiR_Injected
Oct 21, 2007 07:24 AM
aaronhume
Nov 21, 2006 12:00 PM
Joebroni
May 29, 2005 12:43 PM
t0eKnEe
Dec 8, 2004 10:05 PM
Propulsion
Aug 25, 2004 11:02 PM
