hasport mount question (gsr in ek)
www.hasport.com only refers to if you have b series 2 bolt or 3 bolt option...
ebay ads for this mount says that all d series and b series works with this mount except gsr. (im thinking they are saying that because gsr usually has the 3 bolt mount in the integra)
i dont know what post mount I have on my gsr swap but my hasport mount does not match up with it the holes are the same distance apart but the angle is wrong.
has anyone used a 2 bolt hasport mount with a gsr block???
I thought I have an em1 block mount...
is there a different style 2 bolt b series mount that i should be using?
has anyone used a 2 bolt hasport mount with a gsr block??? I thought I have an em1 block mount...
Really? Lol i did... cmon now..Lmao! This pic for reference, i want trying to install a mount on top of a mount. But you can see that the holes that bolt to the block mount are at a different angle than the hasport.
Maybe you want to show the pic of your OWN predicament since this one is obviously wrong and will not serve to illustrate anything other than the ridiculousness of that attempted install.
I would say the problem is.....you overlooked changing the POST MOUNT, the one on the side of the block. Installing any b series engine in an ek requires it
What did i over look? You talk like there is only one post mount that will work for b series into an ek. But im learning there is more than one 2 bolt block mount for b series into ek.The post mount I'm using works for my b series swap into ek perfectly, but does not work with my hasport mount. But that block mount you have pictured is different than the one im using. ill look for that block mount cuz that one looks like it is the right angle it needs to have.
No speaky Engrish? If you posted a pic of your OWN problem we could see whether or not you have the correct post mount as stated above.
Explain to me how it's not my "own" problem. Yes i speaky engrish, i apologize for my grammar. Engrish is my 2nd language.
This is what I'm trying to figure out. I thought I've been using an em1 post mount. This post mount was sold to me as em1 post mount. The has port mount is for em1 post mount but doesn't line up. Did anyone know of using a different style 2 bolt post mount for b series into ek? I was always told there was only one 2 bolt post mount that works. I'm curious to what this post mount I'm currently using is originally from.
I found a block post mount off a 92-95 del sol... it works with my hasport mount... I have a few more pics of both post mounts laying side by side, and one with the hasport mount installed... but I cant upload them, the upload keeps failing???
thank you. I found that post mount and it works with my hasport mount. I think i had a 90-93 integra post mount and it worked perfectly with my stock ek mount. I had an ls and a gsr in my ek with it. I thought I had an em1 post mount the whole time and was confused why my hasport mount didnt bolt up.. .but thank you thank you thank you!!!
[QUOTE=Deetz;47835312]I would say the problem is.....you overlooked changing the POST MOUNT, the one on the side of the block. Installing any b series engine in an ek requires it
i wouldn't say it worked perfectly, as you're putting load on the front of the mount instead of in the middle. (the bracket between the mount and the motor is not sitting like factory)
