B18C in a 1959 Morris Mini
Hi, I am swapping a Jdm Type R B18C in my Morris Mini and had a few questions related to the which USDM parts fit the swap.
Will any B series shift linkage fit the S80 transmission? The length of the linkage is not my concern since I have to cut it to make it fit the mini, however i need to know if the linkage will fit the Type R trans.
Will any B18 distributors work for this engine?
Will any B18 starter work or do i need a JDM specific starter?
Same question with the Clutch and clutch slave, Are these parts specific to the JDM B18C or will any B18 part such as USDM GSR work for me.
Thank you
Thank you
any b series linkage will work, yes. any b series manual starter will work. you will have to use a b series vtec distributor, which harness you use will determine which one to get (obd1 and obd2 have different plugs)
any 92-01 integra clutch will work, as well as del sol vtec or 99-00 civic si.
Superb, Thank you
lejeaune
Mar 23, 2010 07:06 PM
almostjdmeg
Jan 27, 2010 01:06 PM
Muuurph
Sep 27, 2008 08:07 AM
MulletManRockStar
Apr 30, 2006 11:26 AM
