92 accord cruise control
Old Sep 6, 2012 | 11:29 PM
zedjr's Avatar
Default 92 accord cruise control
i have 1992 honda accord ex 2.2 litre. I push cruise control main switch and it lights up. I then push accell and the green dash lights ups also. But cruise doesnt engage. I figured it was servo/regulator. Any help is appreciated.
Old Sep 7, 2012 | 01:22 AM
holmesnmanny's Avatar
Default Re: 92 accord cruise control
Without looking at my car right now as it's late, I know you need to hit the set button. I'm not sure if that's the same as the accel button.
Also, does your speedometer work ?
Old Sep 7, 2012 | 07:10 AM
jdmcertified909's Avatar
let me pull a diagram when i get home
Old Sep 7, 2012 | 06:24 PM
zedjr's Avatar
yes set or accel doesnt engage servo. Yes speedometer works.
Old Sep 8, 2012 | 02:38 PM
dragon_lowrider's Avatar
Have you checked the vacuum line that runs to it? I know there is a t in that line aswell, and if it is not getting vacuum it will not work
Old Sep 9, 2012 | 08:45 PM
zedjr's Avatar
there is a vacuum which i think is plugged coming out of the servo. Is it suppose to be plugged. Is there another vacuum i should check?
Old Sep 9, 2012 | 09:38 PM
There is a big hose that runs down into the frame. Then there is a vacuum hose that attaches to the intake manifold on the side. If either one of those is cut off I gotta think cruise control won't work.
Old Sep 10, 2012 | 09:11 AM
zedjr's Avatar
is there a simple way for me to know which vacuum hose is which. I know what the servo is of course but how to find the hose i dont. How do i know i am looking at right hose?
Old Sep 10, 2012 | 12:55 PM
Old Sep 10, 2012 | 12:58 PM
Old Sep 10, 2012 | 08:08 PM
zedjr's Avatar
wow looks complex. also i forgot to say it is a manual trans. The first cruise button lights then set button lights up the green light on instrument panel but servo never engages. What should i check first?
Old Sep 11, 2012 | 09:34 AM
Tdot_cb7's Avatar
Hey,
I've been reading on this forum for a while now, but finally decided to register to get this one question answered:
How would one go about getting ahold of a copy of that manual?
I've got a regular manual from Canadian Tire, but thats not as detailed as I wish it were.
Thanks,
-TK
Old Sep 11, 2012 | 11:24 AM
its a manual you buy online and download it to pdf. pm me and ill discuss another way to get a hold of it
Old Sep 11, 2012 | 04:40 PM
zedjr's Avatar
first thing to check i am assuming from this is the vacuum lines?
Old Sep 12, 2012 | 01:24 AM
Yes, feel free to take some pics of the cruise control system.
Old Sep 13, 2012 | 06:21 PM
vyper_mike's Avatar
I just bought a '92 honda accord ex yesterday i noticed a similar issue with my cruise control, it will occasionally hold speed, and on the other hand, occasionally slowly, or sometimes quickly, drop speed with the cruise control set. im thinking it is a vacuum leak as well, but am curious about the best way to figure where the leak is coming from?
Old Sep 13, 2012 | 11:19 PM
There's really only one vacuum hose going from the cruise control unit to the intake manifold. I mean, there's a couple that make up one line. Just take em off each spot one at a time and see if any of em feel like they aren't holding vacuum. What you can do if you're lucky is just cut off the edge and put it back on and the part that is now exposed will be good enough to do the job. Over time the part that goes onto the ports expands with age.
Old Sep 15, 2012 | 04:35 PM
zedjr's Avatar
the vent hose,am assuming it is called the vent hose, the bigger hose that goes down into the fender which am assuming the speed control sensor controls, anyways please read on, what does that go to. I tested the vacuum lines and it works. i tested the servo and that works. The vent hose goes down into metal like a a vacuum line is suppose to connect to it on other side. but i see no line thru that hole. i see metal. How do i get to this part of the car if i need to reconnect a line. I tried taking off the fender skirt but i still cant access that part. So one the vent hose is a vacuum line that controls the amount of input on the servo so it needs a vacuum. Am assuming since i see metal that the line on the other side has fallen off or something. Two how do i access this area?
Old Sep 15, 2012 | 05:39 PM
zedjr's Avatar
ok i figured out it is just vent hose to the charcoal canister and means relatively nothing to my problem. So i connect a vacuum to that vent hose to check if the servo works which it did rev up the engine. So what could be my problem.
Old Sep 17, 2012 | 07:27 AM
vyper_mike's Avatar
Another interesting thing, the cruise control drives like an old person with an unsteady foot... sometimes it accelerates 3-4 mph, sometimes it drops 4-5 mph, all on completely flat ground at highway speeds. As i mentioned before, sometimes it will turn on, and i can tell its TRYING to hold speed, but starts to slow down slowly, but not as fast as if there was NO cruise control on, do you know what im trying to say?
Old Sep 19, 2012 | 01:41 PM
zedjr's Avatar
do i need to put pressure into the lines to test any. I did test if it was holding vacuum adn it seems to be cause when i pull last hose off to servo i can hear and feel pressured air releasing. is that good enough test or do i need to be more thorough. what test is next to run?
Old Sep 19, 2012 | 02:38 PM
i would say its an electrical component going out. could be the solenoid or the cruise control module
Old Sep 19, 2012 | 06:35 PM
zedjr's Avatar
Is there a test i can run to find out. I mean will the cruise control module be bad with both cruise lights working. So what should i do next?
Old Sep 19, 2012 | 07:43 PM
everything you need to know is up there just scroll up. it will show you how to test each component
Old Sep 19, 2012 | 08:02 PM
zedjr's Avatar
i dont have pressure pump so i cant run the pressure test. am totally lost on how to test the control module or even what is most appropiate to test next. some direction would be appreciated.
