spoon brakes help
Be more specific what car? And depending on wheels you have on.
You may need the following to fit the calipers
Spoon Twin Block Calipers
Spoon Extended Wheel Studs (ARP do these also)
Spoon Spacer which goes behind the disk
282mm 4 X 100 Disks (EBC do these afaik)
And then pads, fluid etc
Edit: No they don't make calipers that you can just slap on your 4lug.
If you don't know the answer for this you have NO BUSINESS with $1600 jdm brakes. Not only is this info readily available by searching multiple threads in this forum or anywhere on the net but the shop or retailer selling you the brakes will have whatever info is needed. To be honest your question is rediculose. Basically ben.... You are the opposite of jdm.
first of all when did i ever say i bought the breaks?? second of all you have NO BUSINESS talking to me like you know me.. its a question that i had no clue about but now thanks to rising sun i know theres more to it than just calipers. so hop off
