'97 Accord stalls when braking or on hills
So... I am at my wits end with this issue.
When braking or when driving DOWN hill, the engine stalls out completely. It will start back up without an issue once the car is at a dead stop or if I pop the clutch, but when popping the clutch it will stutter horribly before picking back up to normal RPM.
I have replaced the IACV, the fuel filter, checked the fuel pump (pain in the ***...) have checked timing, replaced plugs and wires, tried with different levels of fuel in the tank... No changes.
I even tested by putting the car in neutral and revving the motor up a bit while braking and it still cuts off no matter how much gas I give it. It seems to only be when force is pushed toward the front of the vehicle (i.e. when braking or driving in reverse or on a declining hill.)
Someone please help! The ECU is not throwing ANY codes...
Sounds like a fuel issue. I had the same thing happen to me, but it was the fuel filter. Check the fuel pressure regulator, especially the vacuum hose that is connected to it.
mudpuppy4life
Jan 31, 2015 07:34 AM
Black R
Oct 9, 2011 01:36 PM
Black R
Mar 11, 2011 04:59 AM
89b20crx
Mar 8, 2011 09:54 AM
jeebus520
Jul 9, 2010 10:15 AM
