Engine swap D16a8 sluggish..
Old Sep 6, 2012 | 03:42 AM
Sammy Po's Avatar
Default Engine swap D16a8 sluggish..
Hey guys, i've tried to search but couldn't really find what i wanted.
I've recently swapped over D16a8's from a 91-91 crx.
The car when i take off is very sluggish between 500-2000rpm as if it isn't getting any fuel or like it's not revving. Even when i step on the pedal it doesn't go anywhere.
Someone suggested fuel filter? someone else said injectors? I've checked either of these BUT compression is good, replaced plugs etc blah blah blah...... Also not sure if i've got my plug leads in the right order.
Any information would be greatly appreciated.... newbie q i know so i apologise
Old Sep 6, 2012 | 04:53 AM
v4lu3s's Avatar
RTFM
Default Re: Engine swap D16a8 sluggish..
whats your timing set at?
Old Sep 6, 2012 | 07:40 AM
sde780's Avatar
Sounds like your ignition/mechanical timing is off.
Old Sep 6, 2012 | 04:26 PM
JDpower's Avatar
Yea my dohc zc was doing that it's hard to get the mechanical timing prefect.
Old Sep 7, 2012 | 05:19 PM
Sammy Po's Avatar
ahhh damnit! I've just had everything changed over too, new timing belt etc.
I'll have to go to another workshop i think.
It's revving really low too. On idle it's at around 200-300rpms
Old Sep 7, 2012 | 08:43 PM
swordofdoom's Avatar
Did you convert from the DPFI to MPFI? or is your car already MPFI
Old Sep 10, 2012 | 04:00 AM
Sammy Po's Avatar
car was already MPFI..
I think it might have been bad fuel too....
Old Feb 17, 2013 | 02:41 AM
Sammy Po's Avatar
Muthaf*ckin car is still doing the same thing Grrrrr!!!!
Anyone else know what it could be?
Please help
Old Feb 17, 2013 | 06:39 AM
vtec8200's Avatar
what have you checked? What have you done/remplaced?
Start with a complete tune-up i.e. rotor/cap/fuel filter/plugs/wires/pcv
then check igntion timing with timing light and see if it's off.
If all is right remove the injectors and send them for cleaning, check your TPS reading on the tb, clean out IACV and reset idle correctly, check for vacuum leaks with some kind of fluid (carb cleaner, wd-40 etc) around the tb, iacv, intake manifold. Check your map sensor or swap it with a known good one. By then if all is right I would send it to a reputable shop.
Old Feb 17, 2013 | 09:38 PM
fujiwaratofu86's Avatar
Maybe check and see if the catalytic converter is plugged up?
Posted from Honda-tech.com App for Android
Old Feb 17, 2013 | 11:54 PM
Sammy Po's Avatar
i've had the timing checked, all vacuum lines checked, map sensor is good. Cat i haven't checked. I'll have to take it to a shop. I might just change the fuel filter on the weekend too just to make sure incase it's something that small.
Thanks for the replies guys
Old Feb 18, 2013 | 04:07 AM
GPC91's Avatar
um in your first post you said you dont know if your plugs are in the right order... THIS is what i would check first. its very easy just use google. if you arent firing on a cylinder it will run very rough.
Old Feb 18, 2013 | 06:47 AM
sde780's Avatar
"Had your timing checked?" What did they do? Heck your mechanical timing, ignition timing, or both?
Old Feb 18, 2013 | 01:38 PM
skill178's Avatar
check the timing yourself to make sure, incredibly easy, pull the plug beside the cam and sit something small that cant fall all the way in into the hole (I use a samll but long screw driver) careful not to bind it, and rotate the crank by hand till it reaches top dead center. and look at the gears. check the dist and see if its fully turned one way or close to the middle.
firing order is like follows
(dist)4-3-2-1-(cams)
dist should go 1-3-4-2
(sorry if that's confusing, too lazy to find a picture at the moment, I am a Honda guy after all)
being sluggish but still running indicated mechanical timing, and being a dohc its not fun to set if your not experienced with them so if a show did it its likely it might be off a tooth,
are you sure its a d16a8? because that engine comes from
1988–1995 Civic/CRX/Concerto (UK/Europe/Australia)
1992–1995 Rover 216/416 GTi (UK/Europe)
1993–1997 Rover 216 Sport Coupé (Europe)
found you a pic, should be the same granted its on a z6, if your dist dont sit as far sideways just base it off the flat side
Last edited by skill178; Feb 18, 2013 at 01:46 PM. Reason: found you a pic, should be the same granted its on a z6, if your dist dont sit as far sideways just base it off the flat side
Old Feb 18, 2013 | 08:12 PM
SInce forever's Avatar
theres a air valve at the top of the throttle body,adjust that to make it match with the timing,just play with it,get it to the right idle RPM and see how it does,i had the same problem,you lose soo much power from this.
Old Feb 18, 2013 | 11:55 PM
Sammy Po's Avatar
Yeah it's a D16a8... I'm in Brisbane, Australia
I'll have another play with it tonight and see what i can do solo. The mechanic i took it to i guess didn't know what he was doing.
Old Feb 19, 2013 | 12:04 AM
skill178's Avatar
not sure about aust. but around here I do not trust mechanics when it comes to these old Honda's. if a computer cant tell them whats wrong they don't know.
if you feel confident you can use a long screw driver and set the car TDC, and check the cams. there should be a little hole in the top of both cams were you can put a pin to hold the cams while the belt is set. if the hole's are way off its off timing or it the cams are obviously turned away its out. the dizzy tend to easy to set.
will the car rev up fine? rev slow or fast? stop before the rev limit?
Old Feb 19, 2013 | 10:40 AM
jlicrx's Avatar
spark plug wire order for the D16A8, D16A9, D16Z5 and DOHC ZC is like this:
do you have any codes showing on the ECU?
sounds to me like the camshaft timing may be incorrect
Old Feb 19, 2013 | 11:52 AM
skill178's Avatar
one good thing about the dohc is they do throw a cel code if the cams are out of sync. (atleast a true zc with a usdm teggy ecu does)
Old Feb 20, 2013 | 10:50 PM
It could be your ECU. What ECU are you using?>
Old Feb 21, 2013 | 12:01 AM
~sp33~'s Avatar
EFB055
This is the next thing i would check before spending money on anything else.
Where abouts in brisbane are you?
91 EF DX
17
Jul 15, 2013 05:40 AM
91 EF DX
Jul 12, 2013 07:04 PM
ThatOneOG
Jul 7, 2007 12:57 AM
stivic
Dec 6, 2006 08:56 PM
Neukin
Mar 5, 2003 06:04 PM
