92 Civic CX - D15b8 to D15b7 swap has no power to anything
Old Sep 5, 2012 | 06:43 PM
92civichatch88's Avatar
Default 92 Civic CX - D15b8 to D15b7 swap has no power to anything
To whom it may concern:
I have a 92 honda civic CX hatchback. It came with the d15b8 engine. I blew the motor at 113,000. I did a swap to a d15b7. I hooked up all my wiring and connected all my things. I don't have any power to anything. No fuel pump kick in, no lights, no nothing. I have never done this before, this is my first swap...do I need to also change ECU? Again, no power anything...everything is connected...I am lost..someone help me!
Old Sep 5, 2012 | 10:17 PM
jbpnoman's Avatar
Default Re: 92 Civic CX hatchback issues!!
The motors are too entirely different to expect the B8 ECU to run the B7 engine. Replace with the correct ECU for the engine. You want a P06 ECU.
Old Sep 6, 2012 | 06:41 AM
94eg!'s Avatar
#1 Super Guy
Loved
Check all the fuses in the underhood fuse box. Even the big ones. If your not getting power, that is where I would start.
Old Sep 6, 2012 | 06:56 AM
dirty19's Avatar
Ridin Dirty in Cali
Check your grounds too.
Old Sep 6, 2012 | 07:26 AM
Former User's Avatar
Default Re: 92 Civic CX - D15b8 to D15b7 swap has no power to anything
Pleas create thread titles that summarize the tech problem -- edited.
Old Sep 11, 2012 | 12:57 PM
Thanks to all who have replied/helped out!! Problem was corrected. When I hooked up a battery that was good...my started arched between the gromet and the block, causing me not to get power but just to the block. I have since put a new boot on, fixed the problem!
Crashmaster91
Jun 22, 2017 08:24 PM
RichCMemphis
27
Aug 16, 2016 12:58 PM
weber1
Oct 14, 2015 05:44 AM
KevronsEG
Apr 21, 2002 01:49 PM
