FS: RYWIRE* AEM COIL ON PLUG SETUP
Looking to sell my AEM COIL ON PLUG SETUP off my car. this setup was only used for 2 months. i got this from rywire.com. only reason im selling it is cuz i have a baby girl on the way this sept & no longer plan to keep the car. i've already parted it out a little. i have no use for this on any of my other cars as well. i believe you can install this & fire the car right up cuz it's already all been calibrated by bisimoto & was running on my car so you should only need a retune since it was running on a base map w/ itb's. i was planning to go back after i changed my fuel pump, but things change as you can see!
NOT 100% SURE THOUGH if you can fire this up w/o recalibrating the EPM module, but common sense tells me it's already been set within the EMS. also this setup requires a little of modifying which i've already done. for instance, the k series coilpacks have to be modified to fit along w/ the coil plate. also the EPM module doesn't come w/ the cam key for timing which is off the distributor & it doesn't tell you which way is correct or 180 degress off. all that has been setup w/ this already & will save you lots of time. all you should need is a retune. switching over to this setup takes several hours prior to tuning just to fire up the car.
PRICE: NEW PRICE $1500!!! I NEED THE MONEY! I JUST WRECKED ONE MY CARS...........this setup cost $2k +tx/sh new from the site
link
http://www.rywire.com/catalog/....html
PICS: i don't have pics of my EMS ver2 but it's the 30-6050 obd2b, but w/ the jumper it's obd1 ready! i can get pics if you want.
link
patroick67
Apr 11, 2012 08:28 AM
